It is currently Mon Sep 28, 2026 8:00 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Tue May 10, 2016 10:26 am
mod class actually allow for lux diffs if you wanted
Post Posted: Wed May 11, 2016 2:11 pm
Reubs wrote:
just_cruizin wrote:
Yeah, lux's have been mentioned but the comp I compete in (sometimes) I have to run zuk diffs, may be able to stretch friendship to use a Vit rear on leaves.
The current Tough Tracks rules allow for a Vit diff under a Sierra if I can recall correctly when they were changed at least a year ago.
Tanshi is running sierra LJ hybrid diffs arent you? Or was it the sierra tcase he got through on a technicality. Either way there is a stipulation in the rules it just has o be from the same make, model wasnt as impotant. So Vit floater set up should be viable.
Vehicle: Which one?
Post Posted: Wed May 11, 2016 2:39 pm
Tanshi even has coily bits in his mix-n-match diffs.
Post Posted: Wed May 11, 2016 3:41 pm
yeah I am running zook hybrids.
it used to be that you could only run same make diffs. so Suzuki diffs of any sort.
you can get away with any diff swap in mod class now.
Post Posted: Wed May 11, 2016 4:03 pm
Portals it is then. All problems solved...... Except the dollars
Post Posted: Wed May 11, 2016 4:30 pm
It won't matter what you run Greg, the red mist always beats you :thefinger:
Post Posted: Wed May 11, 2016 5:31 pm
At this point I have to agree. It's a catch 22 at this point. I'm slowly getting better but only seat time in a working vehicle will fix that
Post Posted: Thu May 12, 2016 5:07 am
Sounds like a plan.
Users browsing this forum: No registered users and 136 guests
