It is currently Sun Nov 15, 2026 11:13 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
Vehicle: 1989 1.6 Suzuki Sierra
Post Posted: Sun Sep 05, 2021 7:15 pm
Colin wrote:
RhysE wrote:
How exactly is the IAC cleaned ? And how do I remove it. On a baleno g16b ? Cheers
Pull this off and use carby cleaner and toothbrush and clean throttle valve. There is also a little bypass valve that controls idle, clean this too!
How did you go about cleaning the IAC? did you remove the whole thing, coolant lines and all? Or just undid the 2 bolts and cleaned whatever’s inside?
Vehicle: 2020 Vitara Turbo
Post Posted: Tue Sep 07, 2021 6:39 am
Last couple I did I removed the entire assembly off the car. just put bolts in the coolant lines to stop the mess.
also use compressor to push out any other crud hiding in the corners, just make sure you point away from your face.
Users browsing this forum: Google [Bot] and 46 guests
