It is currently Tue Oct 06, 2026 2:02 pm
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Wed Sep 16, 2009 10:38 pm
here is a pic of a jimny wheel bearing being pushed out
same as coily, ball bearings
Post Posted: Thu Sep 17, 2009 1:36 am
I was amazed with my listings saying they all run the same.
i didn't think it could be true.
After posting this arvo i organised for a late model jimny kit to come to my branch so i could check it out,
i'll post up all measurements on it and numbers i find so you can see if its what you guys think is right.
these aren't really cheap either, i think they are around the $65 + area if i remember correctly, does that sound about right for the kit?
whats the bet the double row ball bearing and the LM800349/11's have the same id/od. so they would appear to fit but wouldn't be able to get any load on the bearings
weaves.
Post Posted: Thu Sep 17, 2009 1:57 am
yeah mate thats the problem, they measure to be the same bearing but they just do not load up, thats why i gave up and repacked my originals lol
Post Posted: Thu Sep 17, 2009 4:42 pm
ok here is what i have found with the jimny kit,
it contains
1 of 54 x 69 x 7.5/9.5 seal
1 of 75 x 87 x 7 seal
1 of Double Row Angular contact Ball Bearing with Split Inner Ring
number on the bearing are - M335 DU4101T MALEK
compared sizes between this and NT,WT. Jimny bearins measured with old callipers and i don't have access to micrometres, seirra bearings sizes taken direct from timken catalogue
DU4101T
41mm - ID
68mm - OD
39.74mm - W inner ring
35mm – W outer ring
LM300849/11
40.988mm - ID
67.975mm - OD
18mm - W
for the LM300849/11 you need a should for the cups to go against to create preload so you can't interchange without making up a spacer to space the cups out to create the correct preload.
i hope this helps with anyone for future bearing replacements
weaves.
Post Posted: Thu Sep 17, 2009 5:56 pm
so thats the answer for coilies, buy a jimny kit :)
Vehicle: 96 LWB Vit, 2.5L powerhouse
Post Posted: Fri Sep 18, 2009 1:58 am
thanks heaps everyone. information on here is unreal haha. i hope this saves some future coily drivers some money on wheel bearings. cheeers
1997 Sierra, daily driver, 60mm coils, 2 inch body
Vehicle: SJ80
Post Posted: Mon Sep 21, 2009 5:05 pm
Ok, so what was the end result of the investigation?
To replace a coily front wheel bearings with generic bearings from a bearing shop like CBC, you need an early jimmy kit?
And the part no was M335 DU4101T MALEK ?
And you retain the original spacers etc?
Is that right?
Post Posted: Mon Sep 21, 2009 9:29 pm
they only list two kits right through,
ask for the jimny kit, with the 'double row angular contact ball bearing'
aslong as you don't have two seperate cup and cone berings your got the right style.
the M335 DU1401T MALEK where just the markings on the one i have here, not the part number CBC/SES/BSC/BD's would reconise as a standard part.
weaves.
Post Posted: Thu Oct 01, 2009 3:11 pm
If your having as much trouble as me with wheel bearings i strongly suggest you check your hubs for play. After paying for shops to do it, i finally had a go myself. The play in the wheel isnt because the bearing is shagged or wrong. I used some rod and 2 bits of steel at either end to hold the bearings together to simulate the locking nut being done up, and there was slight play still in the hub. so im on the lookout for jimny or coily hubs if anyone has any ideas or knows where i can get one. thanks heaps
Post Posted: Thu Oct 01, 2009 3:23 pm
Is that right?
you put it back together the same as the coily was, jimny and coily bearings are exactly the same.
actually the only difference between the whole hub setup between the two is the jimny has the pipes on the stub axle for the vacuum hubs and it has a different bearing locking ring which locates the vacuum hub. But you could use the jimny stub axle if you blocked up the pipes to stop shit getting in there and used the coily retaining ring.. or machined the lip off of the jimny one
Post Posted: Wed Oct 07, 2009 10:49 pm
so i think i hold the key to fixing my wheel bearing problem. sourced some jimny hub assemblies from the spindle with the 4 bolts out to just before the freewheeling hub. my question is, can i just unbolt my bearing hub assembly and stick this one on? the bearings and such are in good order. As samm said in the last post should i block the tubes for the vacumm hubs hub??
Post Posted: Wed Oct 07, 2009 10:57 pm
Hell yes! other wise you WILL let water & shit in, look through samm`s build & it may show what he did.
Post Posted: Sat Oct 10, 2009 6:22 pm
Attempted the hub assembly change today and proved im a dick head. The jimny hubs i got arent even the right ones for some reason
???? the inside diameter of the bearings in the jim hub are alot smaller than my coily hubs. so hopefully i can take them back. I nearly resorted to fire today cause im that over it. i will supply beer and food if someone wants to come and fix my car. Just need to find some coily hubs i hope thats the problem. Fuck it.
Post Posted: Sat Oct 10, 2009 6:41 pm
pm sent mate.
Post Posted: Sat Oct 10, 2009 6:55 pm
email sent
Post Posted: Sat Oct 10, 2009 7:49 pm
Let me know what you guys eventually end up doing
Post Posted: Sat Oct 10, 2009 8:01 pm
he is hitting it up tomorrow i had a chat to him on msn, just a bit of a small hurdle what i said earlier should still work at this stage, he was just worried about undoing the stub axle (spindle whatever)
Post Posted: Fri Oct 16, 2009 1:46 am
Steknig came over tonight to help me out with my bearing issue. They are both fucked!! However, the new one that I had put in is wrong, no surprises either! WEAVES can you please, please check to see what piece of shit I have in mine. The number on the bearing is DAC4168W Koyo brand. It is loose in the housing to the point it has spun n there. Doesn't do up enough to get the load on it, no surprise again. Steknig please comment if i have left anything out or wrong
Just so I'm clear when I go to the bearing shop, what am I asking for?
Post Posted: Fri Oct 16, 2009 2:03 am
What about this one?
http://cgi.ebay.com.au/Front-Wheel-Bear ... 35a40c02ff
Post Posted: Fri Oct 16, 2009 2:09 am
Rusho81 wrote:
look`s the same as what you have , but with out measurement`s or having it in my hand can`t say if it`s rite or not..
Post Posted: Fri Oct 16, 2009 2:15 am
I sent the seller an email letting him know about the issue in mine. I asked him if they are tryed and tested in a coily? Have to wait now I guess.
Post Posted: Fri Oct 16, 2009 2:19 am
mate give up and just burn it. thats where im at with mine right now hahaha. just changed my bearing hubs from coily ones to jimny ones no more wiggle and shiiit. still gotta do the other side before the weekend :| no work for me tomorrow haha. still a funky grinding noise when i turn though but hopefully coming from the other one. good luck mate.
Post Posted: Fri Oct 16, 2009 2:28 am
That sounds..well how to put it nicely..fucked. I hope mine don't come to that.
Post Posted: Fri Oct 16, 2009 2:32 am
yeh bit of a pain but good experience. do you still have your original coily bearings??
Post Posted: Fri Oct 16, 2009 2:36 am
hey rusho,
does yours measure up like this?
41mm - ID
68mm - OD
35mm – W outer ring
i'll call koyo in the morning and compare the sizes they have give me for what you have to this.
weaves.
Post Posted: Fri Oct 16, 2009 2:37 am
left side definately not, no idea what it is! hopefully weaves will come through with the goods and let me know what it is. RH probably not cause it moves also! My fun just starting
Post Posted: Fri Oct 16, 2009 2:38 am
I didn`t have my vernier`s there..so no measurement`s..
Post Posted: Fri Oct 16, 2009 2:54 am
i'll do it first thing when koyo open, and post it here for you
weaves.
Post Posted: Fri Oct 16, 2009 3:02 am
You are a true gentleman weaves, thanks mate
Post Posted: Fri Oct 16, 2009 12:19 pm
Does this mean you're out for tomorrow Rusho?
Users browsing this forum: Google [Bot] and 109 guests
