Print view
Previous topic | Next topic
| Author |
Message |
whib
Joined: Wed Mar 31, 2010 10:30 pm Posts: 24 Location: nz
 Posted: Sat May 29, 2010 4:20 am |
a thread grave dig sorry,
I changed my oil yesterday, i put in some valvoline semi synthetic 10W-40.
the motors a g16a tbi, would this be ok, or should i be puting a different thickness in?
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Sat May 29, 2010 1:59 pm |
...what is the advantage/disadvantage of running thicker/thinner oils? people talk about using the 10W40 mostly, is it better for the car than 20W50, which i run?... mine doesnt use oil, never seen it blow smoke in the 2 years ive had it, and is really quiet (by sierra standards)...
i just use that Valvoline, i think its "XLD Premium" but not 100% sure...
better yet, i'll just go google it and answer my own questions...
shabz
Joined: Sun May 03, 2009 11:30 pm Posts: 646 Location: Melbourne
 Posted: Sat May 29, 2010 2:43 pm |
ScrawnC wrote: I would run a 10w40 in it. I think they hold 4.5-5 litres
According to the book the GV will hold 5.5 litres....in reality its actually closer to 6 (when filter changed as well)
i use the castrol gtx3...or something like that - in the red container....its a 15/40 oil from memory.......never had any problems...
oh and i dont get any chain rattle any more either
shabz
 Posted: Sat May 29, 2010 3:00 pm |
royce wrote: the thought that a bigger number handles more heat is rubbish, likewise your engine runs at a nominal 90 degrees regardless of outside temp!
you're right here royce.....heres a quick breakdown on what the numbers actually mean.
Its all about the viscosity of the oil at cold, and at operating temperatures.
oil A - 20w50
oil B - 10w40
oil C - 5w50
At cold temperature oil A is thicker than oil B, which is thicker than oil C. This is all seen in the first number.
At operating temperature, oil A will be just as viscous (think) as oil C. Oil B will be a little thinner. This is the second number.
So at cold start up, oil C is the thinnest, thus able to flow through the engine easier than thicker oils. However when the engine is warm, oil C behaves in the same way that oil A does.
If engines all run at a similar temperature when warm - why do people choose 'thicker' or 'thinner' oils? Well depends on the car. High performance cars with high tech engines and high tech cooling systems have much lower tollerances than a 25 year old zook, so they'd probably choose a 5w30 or something like that - a 'thinner' oil.
A 25 year old zook at high revs in low second gear isn't getting much air flow, hence cooling, and likely to be running slightly hotter, hence a 'thicker' oil maybe be better. This is because the oil will still hold its chemical properties and do its job - where as a thinner oil at higher temps may not be so great.
hope this helps out
Do a google search and you can find more detailed technical explanations on this but this is the basics...
boballan82
Joined: Wed Mar 31, 2010 10:30 pm Posts: 25 Location: Brisbane
 Posted: Sat May 29, 2010 8:07 pm |
I witnessed alot of testing with Motor Oils by the defence research centre and there findings were that the best oils to use were as follows
1. Mobil 1
2. Castrol Magnatech
3. Penrite
I have used Castol magatech in all my vehicles and had a commodore keep running at 400,000 klm without using oil. Also used in my Rally car and the engine was spotless at each yearly rebuild.
Jester
Joined: Fri May 08, 2009 11:30 pm Posts: 726 Location: Adelaide
 Posted: Sat May 29, 2010 9:47 pm |
royce wrote: the fix for festivas with tappet knock is 5w30 oil country wide
the later WF festiva that is its stock asking for oil, they drive a heap better on it too
foonji
Vehicle: Suzuki
 Posted: Sat May 29, 2010 11:09 pm |
I use Penrite HPR 30 20w60 in my sierra, runs nice.
MacDaddy
Joined: Thu Mar 26, 2009 10:30 pm Posts: 10453 Location: Perth, Australia
Vehicle: Jeep
 Posted: Sun May 30, 2010 4:35 am |
shabz wrote: royce wrote: the thought that a bigger number handles more heat is rubbish, likewise your engine runs at a nominal 90 degrees regardless of outside temp! you're right here royce.....heres a quick breakdown on what the numbers actually mean. Its all about the viscosity of the oil at cold, and at operating temperatures. oil A - 20w50 oil B - 10w40 oil C - 5w50 At cold temperature oil A is thicker than oil B, which is thicker than oil C. This is all seen in the first number. At operating temperature, oil A will be just as viscous (think) as oil C. Oil B will be a little thinner. This is the second number. So at cold start up, oil C is the thinnest, thus able to flow through the engine easier than thicker oils. However when the engine is warm, oil C behaves in the same way that oil A does. If engines all run at a similar temperature when warm - why do people choose 'thicker' or 'thinner' oils? Well depends on the car. High performance cars with high tech engines and high tech cooling systems have much lower tollerances than a 25 year old zook, so they'd probably choose a 5w30 or something like that - a 'thinner' oil. A 25 year old zook at high revs in low second gear isn't getting much air flow, hence cooling, and likely to be running slightly hotter, hence a 'thicker' oil maybe be better. This is because the oil will still hold its chemical properties and do its job - where as a thinner oil at higher temps may not be so great. hope this helps out Do a google search and you can find more detailed technical explanations on this but this is the basics...
Thankyou, that is a good explanation of the oils... so what do you put in your GV ?
Now that the weather is getting colder, i have noticed that i get a couple of seconds of timing chain rattle from a cold start... not sure what oil its got in it, but i am guessing it needs a thinner oil for cold starts...
And what do you think about Semi and Full Synthetic oils, i am guessing they perform alot better, but why, and all cars cant run them, would a Semi Synth be ok in the GV ?, i am looking at the Nulon 5W 40 Semi-Synth Oil for my GV...
shabz
 Posted: Sun May 30, 2010 12:26 pm |
MacBear wrote: shabz wrote: royce wrote: the thought that a bigger number handles more heat is rubbish, likewise your engine runs at a nominal 90 degrees regardless of outside temp! you're right here royce.....heres a quick breakdown on what the numbers actually mean. Its all about the viscosity of the oil at cold, and at operating temperatures. oil A - 20w50 oil B - 10w40 oil C - 5w50 At cold temperature oil A is thicker than oil B, which is thicker than oil C. This is all seen in the first number. At operating temperature, oil A will be just as viscous (think) as oil C. Oil B will be a little thinner. This is the second number. So at cold start up, oil C is the thinnest, thus able to flow through the engine easier than thicker oils. However when the engine is warm, oil C behaves in the same way that oil A does. If engines all run at a similar temperature when warm - why do people choose 'thicker' or 'thinner' oils? Well depends on the car. High performance cars with high tech engines and high tech cooling systems have much lower tollerances than a 25 year old zook, so they'd probably choose a 5w30 or something like that - a 'thinner' oil. A 25 year old zook at high revs in low second gear isn't getting much air flow, hence cooling, and likely to be running slightly hotter, hence a 'thicker' oil maybe be better. This is because the oil will still hold its chemical properties and do its job - where as a thinner oil at higher temps may not be so great. hope this helps out Do a google search and you can find more detailed technical explanations on this but this is the basics... Thankyou, that is a good explanation of the oils... so what do you put in your GV ? Now that the weather is getting colder, i have noticed that i get a couple of seconds of timing chain rattle from a cold start... not sure what oil its got in it, but i am guessing it needs a thinner oil for cold starts... And what do you think about Semi and Full Synthetic oils, i am guessing they perform alot better, but why, and all cars cant run them, would a Semi Synth be ok in the GV ?, i am looking at the Nulon 5W 40 Semi-Synth Oil for my GV...
I use castrol gtx3 - its 15w40.
I've used it in the past on heaps of other cars, and never had a problem. I have been thinking of changing to a 10w40 or 5w40 - mainly for the cold start ups and timing chain noise.....but i've found after using an engine flush and change oil every 7-8 thousand kays i never get the rattle.
I don't know too much about oil blends though. But i know that a fully synth oil has less impurities than a semi synth or full mineral oil....maybe someone else here knows
BJPK
Joined: Thu Feb 19, 2009 10:30 pm Posts: 786 Location: perth
 Posted: Thu Sep 09, 2010 2:03 am |
why do people dislike magnatech so much?
i put it in the sierra the other day and must say im impressed so far.
less piston slap on cold start ups and seems to accelerate slightly quicker due to the lower viscosity!? doesnt blow any smoke even though its a lower viscosity than what i usually run. (not that it did ever blow smoke)
previously been using genuine toyota oil 20/50 because its free from work.
Bruce
Joined: Sun Jun 11, 2006 11:30 pm Posts: 4003 Location: Brisbane
 Posted: Thu Sep 09, 2010 3:02 am |
I've been running 10w40 Magnatech in my Lancer from new (1999 VRX) It's done just over 250k and never had a worry.
_________________ [quote="royce"] I wouldnt mind insulating my rear
atari4x4
 Posted: Thu Sep 09, 2010 3:17 am |
jonno_racing wrote: after killing 2 gti motors from cheep oil.. i have decided nothing but the best.. that extra $60 at the oil change saves me having to spend a day riping the gti motor out and putting a new one in.. oh and the coin! for run in i used mobil 1 fully synthetic 5w25 and i am about to put this in (cant actually buy this off the shelf in aus mates work gets it in) Elf 5w40 fully synthetic, yes its probably more expensive than a bar of gold, but worth it imo
was this before or after the last rebuild?
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Thu Sep 09, 2010 6:11 am |
Slightly off-topic I know, but the other day when I was topping up the oil I noticed quite a bit of gunk under the rocker cover. What is the best way to get rid of this?
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
 Posted: Thu Sep 09, 2010 6:16 am |
By gunk do you mean grey creamy substance?
_________________ Chop
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Thu Sep 09, 2010 7:50 am |
zukmeista wrote: Slightly off-topic I know, but the other day when I was topping up the oil I noticed quite a bit of gunk under the rocker cover. What is the best way to get rid of this?
Oil flush.. & regular servicing..
_________________ I used to be indecisive,
crazynic
Joined: Sun Nov 22, 2009 10:30 pm Posts: 69 Location: Jindabyne, NSW
 Posted: Thu Sep 09, 2010 8:39 am |
In my 99 V6 GV im currently running castrol magnatec professional 10/30..
When I first got the car it had a timing chain rattle on start up for about 5 seconds or so...
For the first couple of oil changes (5K intervals) I used an oil flush...
Ive always used ryco filters on all my cars..
Now there is no start up rattle and does not use oil between servicing so I must be doing something right!
MacDaddy
Vehicle: Jeep
 Posted: Thu Sep 09, 2010 2:03 pm |
crazynic wrote: ... Ive always used ryco filters on all my cars..
While Ryco are good oil filters, they can be Wrong for a GV... the right oil filter, needs a " non oil return valve " in them, or those first few seconds of startup will leave the timing chain without oil, and it will rattle... i found this out, when i had a major service done on my GV 6 weeks ago, and was told it had the wrong oil filter... so i would check that you have the right oil filter...
TheOtherLeft
Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
 Posted: Fri Sep 10, 2010 4:44 am |
MacBear wrote: crazynic wrote: ... Ive always used ryco filters on all my cars..
I thought Ryco's had non-return valves?
_________________ 2002 SWB GV
Lifted and Locked
MacDaddy
Vehicle: Jeep
 Posted: Fri Sep 10, 2010 7:30 am |
TheOtherLeft wrote: MacBear wrote: crazynic wrote: ... Ive always used ryco filters on all my cars..
While Ryco are good oil filters, they can be Wrong for a GV... the right oil filter, needs a " non oil return valve " in them, or those first few seconds of startup will leave the timing chain without oil, and it will rattle... i found this out, when i had a major service done on my GV 6 weeks ago, and was told it had the wrong oil filter... so i would check that you have the right oil filter...  I thought Ryco's had non-return valves?
From what i found out, some, not all...
steak_knife
 Posted: Fri Sep 10, 2010 9:43 am |
That make's two of us....
crazynic
 Posted: Fri Sep 10, 2010 10:22 am |
What the f$ck are you on about just use a Z172 oil filter they have an anti-drain back valve.
MacDaddy
Vehicle: Jeep
 Posted: Sun Sep 12, 2010 6:03 am |
crazynic wrote: MacBear wrote: crazynic wrote: ... Ive always used ryco filters on all my cars..
While Ryco are good oil filters, they can be Wrong for a GV... the right oil filter, needs a " non oil return valve " in them, or those first few seconds of startup will leave the timing chain without oil, and it will rattle... i found this out, when i had a major service done on my GV 6 weeks ago, and was told it had the wrong oil filter... so i would check that you have the right oil filter...  What the f$ck are you on about just use a Z172 oil filter they have an anti-drain back valve.
From what i understand, NO they dont all have that !
You can use a standard Ryco Z172 filter, i aint, i will use the right one for my GV !
royce
 Posted: Sun Sep 12, 2010 6:16 am |
Z418 has a non return valve
172 is a bigger version of a 125 which is a bigger version of a 418, if you think that somehow is bad for your engine you need more alfoil hat
atari4x4
 Posted: Sun Sep 12, 2010 6:21 am |
MacBear wrote: crazynic wrote: MacBear wrote: crazynic wrote: ... Ive always used ryco filters on all my cars..
While Ryco are good oil filters, they can be Wrong for a GV... the right oil filter, needs a " non oil return valve " in them, or those first few seconds of startup will leave the timing chain without oil, and it will rattle... i found this out, when i had a major service done on my GV 6 weeks ago, and was told it had the wrong oil filter... so i would check that you have the right oil filter...  What the f$ck are you on about just use a Z172 oil filter they have an anti-drain back valve. From what i understand, NO they dont all have that ! You can use a standard Ryco Z172 filter, i aint, i will use the right one for my GV !
so what is the "right" one for a gv?
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Sun Sep 12, 2010 6:28 am |
Seeing whats going on here, I went to the Ryco site to where you ask for the correct filter and punched in Suzuki and GV ( Grand Vitara) the answer. No matching part numbers.
_________________ Bad decisions make good stories.
MacDaddy
Vehicle: Jeep
 Posted: Sun Sep 12, 2010 6:29 am |
atari4x4 wrote: MacBear wrote: crazynic wrote: MacBear wrote: crazynic wrote: ... Ive always used ryco filters on all my cars..
While Ryco are good oil filters, they can be Wrong for a GV... the right oil filter, needs a " non oil return valve " in them, or those first few seconds of startup will leave the timing chain without oil, and it will rattle... i found this out, when i had a major service done on my GV 6 weeks ago, and was told it had the wrong oil filter... so i would check that you have the right oil filter...  What the f$ck are you on about just use a Z172 oil filter they have an anti-drain back valve. From what i understand, NO they dont all have that ! You can use a standard Ryco Z172 filter, i aint, i will use the right one for my GV !  so what is the "right" one for a gv?
Until i hear differently, with verifiable facts/info, a Suzuki Genuine Oil Filter !
http://www.suzistore.com.au/shopexd.asp?id=407
steak_knife
 Posted: Sun Sep 12, 2010 6:31 am |
MacDaddy
Vehicle: Jeep
 Posted: Sun Sep 12, 2010 6:32 am |
royce wrote: Z418 has a non return valve
Ah ok... i didnt say bad, just not right, and with an engine thats done 200,000kms, i would prefer to use the right one for it, i dont mind spending the coin to make it last longer...
royce
 Posted: Sun Sep 12, 2010 6:36 am |
$42.50!!!!
ryco is a permitted replacement for any brand anyone here will ever afford, I would rather put the left over $30 into better oil and 5000km oil changes
atari4x4
SuziBlu wrote: Seeing whats going on here, I went to the Ryco site to where you ask for the correct filter and punched in Suzuki and GV ( Grand Vitara) the answer. No matching part numbers.
 i think the internets is holding information from you D?
http://www.rycofilters.com.au/catalogue ... AND+VITARA
SQ625 LWB Petrol V6 2.5L H25A MPFI DOHC 24V 04/98-05 Oil = Z172 Air =A1340 Fuel=Z572
Users browsing this forum: Google [Bot] and 148 guests
