It is currently Sun Oct 18, 2026 10:48 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3
Post Posted: Fri May 14, 2010 12:51 am
whincup wrote:
if i can afford it, im going to see about getting mine on a dyno run (no tuning, just on the dyno and do the test then off) before i get my exhaust changed, then again after. depends on what they charge for a single run...
btw, i think im getting the 2"...
The only possible way this could work is if you had all the different variant exhausts made up already an just bolted them on one after the other whilst on the dyno. Just as important as the mods themselves are the operator ( use the same one) ambiant temp and relative humidity, correction factor on the dyno, even tyre temp can play its part ( although I doubt it would be seen on any car less than 500HP )
So what I am really saying here is don't waste your money.
Pete
x2
just do it, anything will be a vast improvement over the stock equipment
Post Posted: Fri May 14, 2010 8:03 am
Pete
Xjustastaggeringaamount
You're going to burn more money than your exhaust is worth to find out that you've added less power than the dyno can accurately measure- i.e more variation between runs than the gain.
Vehicle: 75 Cruiser
Post Posted: Fri May 14, 2010 8:24 am
yer it's like extractors on a hilux, before you could go slow and no one would notice, but with extractors, they all notice how slow you're going.
I'm surprised anyone can feel a 5% difference, i think it's all mental pompoms
Post Posted: Fri May 14, 2010 8:27 am
But Steve, that's 5% , huge friggin power gain!!!! 8O
Post Posted: Fri May 14, 2010 8:35 am
not if youve only got 1-2 horse power like most 2.4 diesel luxes :wink:
Post Posted: Fri May 14, 2010 8:39 am
Good point, thay have so much power that thay fall over all the time!!!! 8O :roll:
Users browsing this forum: Google [Bot] and 215 guests
