It is currently Mon Oct 12, 2026 6:53 am
Post new topic Reply to topic  [ 98 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Posted: Sat May 29, 2010 10:42 am
Especially when, if you open the hood fire jumps on ya
Post Posted: Sun May 30, 2010 9:13 am
This is gonna be fun..
There was about 1/2 hr of light left,, so I thought that I would have a go at getting to the Thermostat without removing too much.. So just took off the Air intakes.. HHAhaha
You can't even get into there with a socket - sticks out too far, and there's no room for a ring spanner cause its too long...
Gonna be pulling stuff out like steknig said
Post Posted: Mon May 31, 2010 6:41 am
AAAAAAAAArrrrrrrrrrrrrrrrrrffffffggggggggghhhhhhhhhhh
So I swung the Alternator around,,, both Bolts out of the Thermostat case, but it won't slide off of the Thermostat case outlet pipe.. Would this just be because I am pushing against the hoses.. or am I forgetting something?
Post Posted: Mon May 31, 2010 7:11 am
You only need to take the black plastic part off, the bit the hose goes on, 3 10mm headed bolt's from memory..
Post Posted: Mon May 31, 2010 7:19 am
problem is no tools fit in there, unless i remove the manifold....
Plus I just cranked it with a Jimmy Bar.. Which has free'd it up... Just need to disconnect the hose to the Thermostat cap and I can do it on a work bench...
Nothing like over committing.
Post Posted: Mon May 31, 2010 8:01 am
8O cracked in a good way or a bad way??
Post Posted: Mon May 31, 2010 9:26 am
I would say in a good way, but the mother doesn't fit between the block and the alternator.. which is push down as far as it will go without removing.. I've run out of light now... ggrr
Post Posted: Mon May 31, 2010 9:57 am
Take it off, your only 1 bolt off anyway..
Post Posted: Mon May 31, 2010 10:02 am
Ok, I will in the morning, as soon as I can see... just looked like a lot of wires going onto it... I'm a total chicken pulling things out... its crazy, cause I can't wait to cut a hole in the panels for a snorkel, but pulling a few bits off the engine, and it puts me in a cold sweat.
Post Posted: Mon May 31, 2010 10:11 am
Hahaha "Jimmy Bar" in a Jimny hehe good one peter.
hey nice job with the photos hey gee I hope it fixes the problem.
One plug & one 10mm nut, you should be fine..
Battery's disconnected yes???? :wink:
Post Posted: Mon May 31, 2010 10:33 am
Was hopeing someone would appreciate that!!
Hell yeah, was pouring hot water on the hoses to losen 'em up so didn't want to get fryed
Post Posted: Tue Jun 01, 2010 6:46 am
##NOTE##
NOT RECOMMENDED for People with Big Hands, & Bad Tempers
Finally got the Case out today, was un-able to remove the Alternator as previous tamperers have threaded the final bolt on it so It was in the too hard basket..
I found that if you remove the white plastic clip that holds the throttle cable, you can remove the 2 bolts holding the Alternator then swing the Alternator down quite low. Once the top 2 hoses are removed from the Thermostat Case, Heated up the Large bottom hose - that traces back to the Radiator, twist the Case back and forth a few times, line it up with the available space, and give it a yank.. hey presto.
So it took me a long time to get the case out, 10 minutes to give it a good clean and replace the Thermostat, and about an hr to get it all back in, including the air hoses etc.
Post Posted: Tue Jun 01, 2010 7:29 am
Nice work!!!! :P :P :P :P
Before anyone tells you that the top alt bracket is back to front, I'm going to say that the M eng right across the range , all have the adjuster set that way from factory..
Ive swapped a couple around cause I get bored some time's.. :P 8O :roll:
Post Posted: Tue Jun 01, 2010 8:23 am
That wouldn't have bothered me,, it would of, if someone said that I had done something wrong at the very bottom and had to pull the whole lot out and start again... Cheap Zook for sale, lol
Post Posted: Tue Jun 01, 2010 8:33 am
In that case!! the lil brass bit on the thermostat, I normally cut them off.
Give ya $50 for it. :P :P
Post Posted: Tue Jun 01, 2010 10:06 am
8O ...... :D
Post Posted: Wed Jun 02, 2010 11:16 am
Gee peter I wasn't gonna say anything after seeing all the trouble you've gone too and you've done a super fine job too.
I was hoping you put the thermostat in its housing with the little brass thing and its hole to the top. I'm sure you did as this greatly helps with letting air out of the housing when filling with water.
It looks like you did, I hope your Jim is much happier now.
Post Posted: Wed Jun 02, 2010 11:56 am
Hey Gman
Is this what you mean?
Post Posted: Wed Jun 02, 2010 9:26 pm
yes thats it, how can i doubt you you've covered all bases and once again taken all the photos too. how do ya keep your hands so clean doing these kinda jobs? :)
hows the Jim going too? better?
Post Posted: Thu Jun 03, 2010 7:06 am
:lol: I have to admit I washed my hands, everytime I took a photo I had a drink of coffee 8O
I'll find out on Saturday, Going to be following a 80 Series around all day, see If I can put his 6inch lift & 37 inch tyres to shame... or just embarass myself :oops: .. Did have a screeetch coming from the fan belt when I finished, hadn't pushed the alternator down hard enough.
Only had a problem in heavy boggy sand, so this should be a good work out.
Post Posted: Thu Jun 03, 2010 7:12 am
That was more so that other's like me (mechanically challenge) can do it too, O yeah and so when people tell me I put the jigameThingabobby on the wrong way I can say which picture is that in. :? :lol:
Cheers for all the help too everyone!! I didn't know Arthur from Marthur..
Post Posted: Thu Jun 03, 2010 7:32 am
That one should have a penis. :roll:
Vehicle: 93 Sierra
Post Posted: Thu Jun 03, 2010 8:29 am
We'll just believe ya on that one, hey Stekkie?!? 8O :P :D
Post Posted: Thu Jun 03, 2010 8:37 am
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Post Posted: Thu Jun 03, 2010 10:41 am
:windowface:
I guess that decides it then... My Jimny is Marthur
Post Posted: Sat Jun 05, 2010 3:04 pm
Yep, Thermostat & Cooling Flush did the trick.. Marthur is doing good!!!
Peter
Post Posted: Sat Jun 05, 2010 9:54 pm
Peter
Armsup Armsup peaceout :P
Post Posted: Fri Jun 11, 2010 5:31 am
So the next job has just begun.. Want to replace the heater core, while I'm fitting the central locking and changing the standard speakers over.
How do you get the dash out of these things?
Found the screws where, under and around the head unit + ash tray, near the doors, 2 where the speedo is, 3x in the glove box, So now the bottom is all loose & floppy but it still doesn't want to just Yank out,, How do you detacd it from the top? does it all come out in 1 peice?
Peter
Post Posted: Fri Jun 11, 2010 5:36 am
are you sure you want to go down that path? its a huge job.
Users browsing this forum: Google [Bot] and 325 guests
