It is currently Sat Nov 14, 2026 4:24 pm
Post new topic Reply to topic  [ 422 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 15  Next
Poll: Has your Jimny ever experienced steering wobble
Yes but was fixed 19%  19%  [ 24 ]
Yes and keeps resurfacing 59%  59%  [ 76 ]
No never a problem 22%  22%  [ 29 ]
Total votes : 129
Post Posted: Wed Jan 19, 2011 8:49 pm
The bush's that come in the tough dog panhard rods were are super tight fit, i had to wedge one on the brackets out just to get it in.
Post Posted: Wed Jan 19, 2011 9:00 pm
I had to use a jack to force mine in 8O
Post Posted: Thu Jan 20, 2011 4:54 am
I had to use a jack to force mine in 8O[/quote]
8O
Just before i left i took my jimny for a quick drive and guess what? it's back :( so i'm hoping it will go away again when i take my RTC of to put my new drag link on and i'll see if it make any difference, with the RTC and with out.
Post Posted: Thu Jan 20, 2011 5:25 am
8O
Just before i left i took my jimny for a quick drive and guess what? it's back :( so i'm hoping it will go away again when i take my RTC of to put my new drag link on and i'll see if it make any difference, with the RTC and with out.[/quote]
Will be an interesting experiment.
Post Posted: Thu Jan 20, 2011 5:28 am
8O
Will be an interesting experiment.[/quote]
Yes it will be, i will let you know how it goes.
Post Posted: Sat Jan 22, 2011 12:35 pm
Hey guys, I wouldn't complain if I was you, Suzuki has a very easy way of fixing it, that is IFS. :x
Lets keep the only current day completely non IFS 4WD with the right kind of suspension hay? :wink:
Thanks
Hayden
Post Posted: Sat Jan 22, 2011 12:41 pm
Thanks
Hayden
It's not a matter of complaining, it's a bit of a safety issue.
Post Posted: Sat Jan 22, 2011 6:23 pm
Have you take it to a suzuki dealer yet?? :?
Post Posted: Sat Jan 22, 2011 9:30 pm
Nope not yet, i will wait til i get my new drag link and i'll take my RTC off before i do an see if that make's any difference.
Post Posted: Sat Jan 22, 2011 9:36 pm
I'm going to type it out again, this time I'm going to make it a lil easyer to read.......
ADJUST THE F*#KING KING PIN'S EVERYONE!!!!!
:P It work's, I've done lot's & lot's & lot's & lot's of em... :P
Post Posted: Sat Jan 22, 2011 9:51 pm
Why will they be out on a car that has only done 5,500 km's though?
What causes them to need adjusting?
Have suzuki admitted it's the problem?
Vehicle: SWB GV
Post Posted: Sat Jan 22, 2011 9:58 pm
Sorry Stekky, what are you trying to convey here?!??!
Beer Fairy
Post Posted: Sat Jan 22, 2011 10:11 pm
5'500km, you've driven it, so one "could" say it's possible "some" thing's may need adjusting?? you have larger that factory tyre's fitted, you have raised it making std caster unachievable.
We are a lill harder on them than Mr Suzuki thought we would be, he made a cheap lil run about that "could" be taken up a dirt track or beach (not at speed & not the type of track's we like to head for)..
I know of some one on this forum that has a copy of this "secret fix" & everything HAS BEEN covered in this thread.....
Everyone asks why lift should affect it???
1. Your caster is out ( IMO it never had enough anyway)
2. A part's fitter has put spanner's to YOUR car, this is an un known factor, he "could" of letf bolt's loose or over tightened damaging mount's, bolt's or bush's. ( from Suzuki's point of view)
3.Your drag link is now of it's desirable angle.
4. Bigger tyre's are always fitted at the same time or very shortly after, giving a greater weight one the 4 lil bearing's that hold the hub's to the diff housing ( bringing us to the point of the piss weak f*#cking housings)
If you don't like the decision of car you bought, sell it & buy a leafy.... :roll:
Post Posted: Sat Jan 22, 2011 10:40 pm
lift makes the angle of the arms worse too, try pushing a wheelbarrow with one hand then try pushing it with the handles higher up in the air
Post Posted: Sat Jan 22, 2011 10:56 pm
I will take it to suzuki and get them to adjust the king pins then.
Cheers.
Post Posted: Sun Jan 23, 2011 8:31 pm
Cheers.
I reckon there's a good chance you'll be paying for it as they'll possibly say your mods have voided the warranty.
Post Posted: Mon Jan 24, 2011 4:04 am
What is the best way to adjust the King pins. As mentioned earlier I took my Jimny to Pedders and they said the bushes and steering box were fine and were surprised when they removed the caps there were no shims . They then said they would have to machine the plate first to fit shims?. They even spoke to the local Suzuki dealer and they had no idea so I said I would find out a bit more before deciding what to do.
Paul
Post Posted: Mon Jan 24, 2011 4:37 am
Check out this older thread. Info has been gathered over time and is spread out a bit. The shims are shown in the last post of page 3.
More wobble and shim info
Post Posted: Mon Jan 24, 2011 4:56 am
Have a read here
www.niumotorsports.com/formula/Learn/Su ... ension.pdf -
Could help..
Post Posted: Mon Jan 24, 2011 5:42 am
Thanks for the info Zukenutter and Kenn.
Steak_knife, I copied this from that link and want to know if you still think this is the best fix.
Do you want the factory fix????
Steering dampener, adj steering box ( only ever a slight adjustment) & machine the rotor`s, this HAS worked every time I`ve done it & wiil normaly last 40k before the rotor`s need to be skimmed again.
Also, still want to know what is the best way to pre load.
Cheers, Paul
Post Posted: Mon Jan 24, 2011 6:46 am
Do I really have to type it all out again??? 8O
Post Posted: Mon Jan 24, 2011 7:37 am
Sorry mate, but on one post you state to adjust the preload on the kingpins and on the older post you state that the factory fix is to add dampers, adjust steering box and machine the rotors so Yes, please type out which one works as it is not too clear to me.
Cheers, Paul.
Post Posted: Mon Jan 24, 2011 8:32 am
They all work, depending on what need's adjusting, if the wobble start's when braking then the rotor's & steering box adj, if still slightly there fit a dampner, while the rotor's are off the pre load & king pin play should be checked.
This is what I used to do, step by step. ( I'm going to skip the test drive:roll:)
1. jack up front & stand's under diff ( leaving enough room for the leading arm bolt's to be checked.)
2. check for movement in the king pin's & wheel bearings while the wheel's are still on.
3. remove wheel's, caliper's & rotor's. ( rotor's get machined if needed)
4. drop tie bar & drag link's off & out of the way.
5. remove wiper seal's & check for ANY sign's of rust/water, if there's any, the king pin bearing's get replaced.
6. check for drag on hub ( the wheel bearing hub & stub axle should really be removed, they will cause drag, but not much, so they stayed on for most of the one's I did.)
7. if adjustment needed ( from memory the drag is 4.6kg) remove the king pin's one by one & ad 1 shim per, checking drag each time a shim is fitted, only once did I only fit one per side.( king pin's tightened before drag checked) I also greased the bearing's while the pin was out, didn't get paid by suzuki to do so, but just something I did.
8. re fit wiper seal's after a hand full of grease jammed into the swivel hub.
9. back off ALL bolt's & re tighten on the leading arm's, pan hard arm's & just cause your there, the shock's ( some of the older Jim's had the rear of arm bush's replaced, there was a cut off date/vin range before a stiffer bush was fitted factory)
10. re fit all bit's you removed. (not going to type it all out.... :roll:)
11. adj steering box, which is better of left to some poor bugger that knows how to do, I have had to adjust & re adjust several time's, so please take care if you going to adjust your self, as an improper adjustment can/will bugger your steering box .
12. drive the no more wobble jim & enjoy the now tight feeling steering.. :P
You will notice the steering is stiffer, so those of us with the pov pack's with out P/s, you will be working a lil harder to turn the wheel, but, this extra drag is what is needed to achieve the no wobble.
Notice I didn't mention a dampner???? not all need em, but I highly recommend fitment, & not the RTC shit, just a dampner.
P.S. any thing I have missed I will ad later & spelling mistake's & grammar you can shove!
:P Steve.. :P
Post Posted: Mon Jan 24, 2011 8:37 am
One thing i did notice is the steering feels very very light, but is because the castor angle is out?
Post Posted: Mon Jan 24, 2011 8:50 am
That & you more than likely haven't enough drag on the king pin's..
If a Jim had lift, I was informed by Suzuki to send em away to return the car in a std state, other wise the work would not be carried out under warranty.
Like wise any courier, Energex, Aus post, security ect would not be warranty as it was considered "extreme condition's", & before you jump up & down about what "extreme condition's" are, the head engineer from japan spent a few week's here & said the whole of Australia should be classed as that, most other jap manufacturer's agree..
Post Posted: Mon Jan 24, 2011 9:13 am
Mate, really appreciate all that info. Thank you very much.
Paul
Post Posted: Mon Jan 24, 2011 9:21 am
I know all the books talk about castor and heavy steering but my mini with race tyres and 2.5 turns lock to lock I can go from no castor to double factory and I cant tell the difference, on a solid front end 4wd tight bushes and scraper seals ( Suzuki used to call these very important) will make the steering heavier than castor
Post Posted: Mon Jan 24, 2011 9:37 am
Paul
I've type that or similar out several time's in pm's, so now it's out here I shouldn't have to type it out again.. :D
Just to clarify, the shim's that add drag to the swivel hub's are the lil washer looking one's, the other square one reduce the amount of drag..
I can't remember the dimension's of the lil shim's, & I don't have assess to the info that I used to anymore.. :(
Post Posted: Mon Jan 24, 2011 9:40 am
Jimnys do have very light steering, castor is definitely noticeable when it's too far negative, steering becomes lighter and very jittery. Even a bit scary sometimes. going back to standard is definitely better and I will soon know what positive caster feels like.
Post Posted: Mon Jan 24, 2011 1:47 pm
:lol:
Rather amusing. This is why some overseas model cars just don't suit Australia at all IMO.
I don't usually comment on this sort of thing; but that numbered list of Stekky's should be put in the "good tech" section. So its easier to find in the future, and the poor bloke doesn't end up typing it again! Especially considering this issues comes up often.
Clearance Hole Technology :P
Users browsing this forum: Google [Bot] and 43 guests
