It is currently Fri Sep 25, 2026 8:42 pm
Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3
Post Posted: Mon Dec 06, 2010 9:05 am
steak_knife wrote:
zuk85 wrote:
lol ive driven and fixed every kind of special fucked up piece of shit there is, and ive listened to every kind of special car owner's idea of whats going on, people cant call oil smoke blue
now shit the fuck up, accept you just did a course thats taught you fuck all (I did it while still at school, feel special now princess) and stop pushing the same line cause that's what a teacher told you, we know the problem, the rings aren't bedded in, they cant and wont ever bed in and given the way the bores on these engines wear I doubt they ever will with any amount of honing
u have no idea do u, i really fell sorry for u now prolly sitting at home all pissed off and shit go back to your garage then and work up a million more crappy 1 liners of shoving things and sitting down
Royce is one of the dumbest people I know. :roll: So he's probably wrong :wink:
Nar, you know me... :lol: :lol:
I said people. Not degenerates. :roll:
Post Posted: Mon Dec 06, 2010 9:08 am
Can you get a compression test done? If oil is getting past the rings then it should show up in a comp test.
Post Posted: Mon Dec 06, 2010 9:11 am
I dont have a tester, But I might take it to a mechanic and get them to do it.
So i take it that if comp is ok, it is water, if comp is bad, then it is rings/oil?
thanks
Vehicle: 4wd
Can someone move this to the good tech thread please.
Watch out or you'll get sued.
Vehicle: suzuki sierra coily
Post Posted: Mon Dec 06, 2010 9:12 am
I going through this whole process as well. And wats making me think is this..
I had a falcon come into me shop. Starting fault. It was autually a leaking head gasket and hydro locking up. But when it did start it blew thick white steam/smoke that hung around for awhile. And did it stink. Just thought I'd though it in there.
Post Posted: Mon Dec 06, 2010 9:13 am
there are 2 sets of rings on a piston, the compression pistons that hold the air fuel mix up top and the oil rings that hold the oil down low, usually they wear the same amount so smoke = rings, in this case it could be unrelated if they are mucked up and not working
Post Posted: Mon Dec 06, 2010 9:21 am
junek wrote:
If i cruise down a hill in gear but no accelerator then floor it, it blows huge amounts of smoke. But it is definately WHITE (or basically white)
Mine does the same. This is after a 20 thou rebore and new pistons/rings 12 months ago. Valve stem seals replaced too.
My suspicion is that a ring may have been broken when installed. :?
I hate smokey engines but eventually you just get over it. :(
SS
Post Posted: Mon Dec 06, 2010 9:27 am
hahah. Problem is, the guy behind me in traffic will not get over it and i reckon the cops will not like it either!
pretty sure the rings went in ok...although not necessarly the 'right way up'
Post Posted: Mon Dec 06, 2010 10:15 am
What about the ring gaps? Hope you didnt line them all up.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Mon Dec 06, 2010 10:31 am
Pull the plugs and look at the electrodes.
Vehicle: 07 vvt jimny
Post Posted: Mon Dec 06, 2010 8:51 pm
thanks
it could be both. as the compression will either blow past the rings or blow through the head gasket into the radiator.
drive it down to your mechanic quickly ask him if he can do a CO2 test from your radiator fill point would take no more than 5 mins of his time. this should determine if any sneaky gases are sneaking past your head gasket.
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Mon Dec 06, 2010 9:01 pm
junek wrote:
WOW......that got outta hand!! haha.
thanks everyone for helping even if you have different opinions.
Sorry to take sides, but i think it is smoke, not steam. Smoke cos it hangs around for ages as i drive down the road!!
However, it is white. Very white with a slight blue tinge i guess. In my limited experience, i would say it is mostly oil.
The head gasket went on the right way up - there was only one way it would fit.
At the end of the day, the evidence fits the crime - "industry standard" of honing any bore a new piston and rings goes to tells the story. I fucked up. - new rings, gaskets, pistons etc but no honing.
Although...just to keep the debate going longer...the smoke has no hint of black or any darkness as suggested it would if oil was blowing past the rings.........
have u checked your oil colour or smell yet just pull out the dip stick and check???
fuely smell would indicate rings, while milky white oil would be the head gasket eaisest way for u too tell without any more of the fuss from us, is to go outside and check .
sorry CHOP :P
Post Posted: Mon Dec 06, 2010 9:19 pm
does it use watter?
Post Posted: Mon Dec 06, 2010 9:22 pm
zuk85 wrote:
check???
fuely smell would indicate rings, while milky white oil would be the head gasket easiest way for u too tell without any more of the fuss from us, is to go outside and check .
or a fucked fuel pump :wink:
Post Posted: Mon Dec 06, 2010 9:29 pm
OK so where I work is shit, I like what I do (when I do it) I sort of think the industry I am in has a lot of potential but there are just parts that in the current combination will never work so its time to go
so you lot have to work for your forum access, find me a job
Criteria, North Brisbane and not long travel times sitting in shit traffic, but also keen in FIFO stuff if its interesting
Office or Hands on stuff, not interested in selling shit or lying to people to con money from em (so no retail bullshit)
no quals other than half an apprenticeship and a cert that says I know how to tell people what to do, but by now most of you should have half an idea about what i'm like so get seeking and find me something, I suck at reading job ad's
now i know why he is pissed off.
and a serious question how would a fucked fuel pump put fuel into the oil??
sorry CHOP :P
Post Posted: Mon Dec 06, 2010 9:31 pm
zuk85 wrote:
check???
okayyy then..... lol
i am meaning for him to smell the dip stick not the side of the block lol come on....
sorry CHOP :P
Post Posted: Mon Dec 06, 2010 9:35 pm
zuk85 wrote:
zuk85 wrote:
check???
go and get your self a mechanical fuel pump and have a think about what separates the fuel and the sump. :wink:
Post Posted: Mon Dec 06, 2010 9:39 pm
i have one lol i know they are controlled by the cam shaft.
and i just got it lol
still if he does a quick check on the dip stick it will give him an idea where to start hey.
sorry CHOP :P
Post Posted: Mon Dec 06, 2010 10:13 pm
dip stick - noticed some small bubbles, but not generally white or milky. That was after a drive.
It smells like oil! haha. Can really smell any fuel...
Does not seem to be using water. But I have only put about 40km's on it.
I dont think it is water - the smell is quite pronounced. Stinks like shit actually.
Asked a few local mechanics if they could do CO2 and compression. They all said, don't bother, it needs honing and I am an idiot for not doing it in the first place.
I am sick of trying to be a mechanic, Looking for a new engine or to sell it to someone who will fix it themselves.
Post Posted: Mon Dec 06, 2010 10:35 pm
nah man you can fix it :D:D we live we learn.
sorry CHOP :P
Post Posted: Mon Dec 06, 2010 11:14 pm
Yep don't get down hearted.
We have all made BIG errors.
Just asked Royce :-)
Post Posted: Mon Dec 06, 2010 11:17 pm
best advice ever given on az
Post Posted: Tue Dec 07, 2010 12:18 am
Thats a big call..
I reckon TOGTFO FTW :lol:
Post Posted: Tue Dec 07, 2010 2:51 am
Have you got the head and big end tensions??
Users browsing this forum: No registered users and 161 guests
