It is currently Tue Oct 27, 2026 9:35 pm
Post new topic Reply to topic  [ 130 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Post Posted: Wed Feb 09, 2011 11:42 am
sounds like good customer backup, better then nissan anyway
Post Posted: Wed Feb 09, 2011 11:46 am
+1 that's pretty good customer service, that recall was posted on 06/08/10.
bogged from that thread....
I would buy the latest ORA arms - in fact I'd buy Rob's 4.5" lift kit which includes his arms if I could afford to.
Rob is currently offering a Lifetime guarentee on his latest arms.
Post Posted: Wed Feb 09, 2011 11:51 am
New arms look alright.
Vehicle: Jimny
Post Posted: Thu Feb 10, 2011 6:33 am
i have decided im more then likely going to purchase the kit. as rob has given me a deal on some other products
DONT BUY A GQ! zooks are better. i have both :)
Vehicle: 89 Vitara jlx SWB
Post Posted: Thu Feb 10, 2011 7:23 am
I went to put a 5 inch lift on my jimny. Scary too high. But looked awesome. Be prepared with at least 31 inch tires and massive offset or wheel spacers like the ORA Jimny was on by the way. I took the 5 inch lift off if your wondering, too high for me. I think their 3 and 3/4 would be a better lift set, and cut guards to fit bigger tyres. The cops will notice you with a 4.5 inch lift if you drive anywhere near citys or traffic. Sorry I didnt take any pics I put it on in the afternoon and took it off in the same afternoon cause I need the car to drive to work the next day and I only have 235/75 15r. No way I was going to drive down the highway with that size tyre and lift felt like it would blow over...
Post Posted: Thu Feb 10, 2011 7:25 am
5" what kit is that?
Are you on selling the kit now?
Post Posted: Thu Feb 10, 2011 7:30 am
Custom sort of made. bits of everything from everywhere. The coils are made by dobinsons and the shocks were sourced from rancho. Oh I forgot get a new steering arm made up! Too short you will have to do a dodgy and move the adjust the pitman arm down a bit. Not the best idea. Get a custom one made, or make one. At full flex the steering turned all the way over to one side.
Post Posted: Thu Feb 10, 2011 7:35 am
Ok shame you didn't get any pics! :(
Vehicle: Jimny
Post Posted: Thu Feb 10, 2011 9:10 am
so i need to make a longer one
Vehicle: Jimny
by steering arm are you reffering to the drag link?
Post Posted: Thu Feb 10, 2011 9:26 am
Just want to know what are bumb stops? i have lifted my car 2 ses and 2 inch body. how hard is it to chop the guards?
Post Posted: Thu Feb 10, 2011 9:37 am
www.bigjimny.com/image...imming.pdf
Even with a 80mm lift 2"BL and he still had to chop the guards.
Post Posted: Fri Feb 11, 2011 6:23 am
Bump stops are the rubber blocks that stop the axle hitting metal on metal when the suspension compresses. They are attached to the chassis or inside the coil spring.
Moving them down (so further away from the chassis) prevents the axle from moving up as far so there's more room in the guard for the tyre.
cutting the guards might only involve some careful work with a 4" grinder, or may involve welding and fabrication - it depends on how far you need to cut. Obviously the moment you fire up a grinder on your car you've massively reduced it's resale value, so you have to know what your getting yourself in for.
On a jimny, lots of the guard cutting required to fit larger tyres is hidden under the plastic guards. Still, cut the wrong bit or too far and it's easy to make a bit of a mess.
Post Posted: Sat Feb 12, 2011 9:57 am
ok I put the 5 inch lift back on the jimny and borrowed a mates huge offset rims and 31s. I'll post some pics tomorrow. It looks awesome with the rims and 31s. Kinda like ORA but not as big tyres. Still not sure I want it. Would anyone be interested in the 5 inch coils and rancho adjustables to suit? or I will probally return them and just get some adjustables for the 3 inch lift.
Post Posted: Sat Feb 12, 2011 10:04 am
Did the 31's rub?
What was the gearing like?
Post Posted: Sat Feb 12, 2011 10:10 am
Na no rubbing, but I cut the guards. Gearing is all good with the sierra case in. Still crawls so slow.
Post Posted: Sat Feb 12, 2011 10:17 am
Oh and the drag link is all good. I had it up in the air still with the shocks still unconnected at the bottom and thats why it was all stuffed up. Should be all good with no mods needed. I was really tired. lol.
Post Posted: Sun Feb 13, 2011 6:59 am
The bottom seats for my coils are just "offset coil spacers". there is no difference between them and a plastic one.They are not welded to the arm they seat neatly into the original coil seat ,then the coil sits in to them .They are a much better idea then running a 3in coil as it stops the coil bowing out by giving it a level seat.
As for strong enough they are made from 6mm plate and 6mm pipe so there stronger then any thing else in the car.
Post Posted: Sun Feb 13, 2011 7:20 am
kemlar: Have you got pics yet?
And what panhards rods are you using?
Post Posted: Sun Feb 13, 2011 9:09 am
let me know on a price, can u get a pic of full flex also, cheers
dodgy brothers mechanical
Vehicle: Jimny
Post Posted: Sun Feb 13, 2011 11:44 pm
wow suddenly dont think i will be getting the kit anymore. 20 percent for import dutys
Post Posted: Mon Feb 14, 2011 6:57 am
8O 8O
Post Posted: Mon Feb 14, 2011 7:05 am
Do I post photos on here? Its sort of got to do with ORA kit... Another way of doing it. I took it off again. The coil and shock fouled. hmm not so good can't return the shocks now haha.
Post Posted: Mon Feb 14, 2011 7:07 am
Start a build thread! but maybe post the pics here. What was the ride like? Am looking at getting ranchos for the rear of my jimny.
I'm using Tough Dog panhard rods. I got some pics, but not at full flex.. It started poring down and I had to take it off cause of the whole scratching the shock thing.. do you wanna see.
Post Posted: Mon Feb 14, 2011 7:08 am
Yes plz!
Post Posted: Mon Feb 14, 2011 7:10 am
Ride was awesome!! so soft and bouncy at number one settings.. I'll post some pics. And the pics I am posting I realize that my number plate is on them. But I am too lazy to put in photoshop and blank out. Plus it dosent look like this anymore.
Post Posted: Mon Feb 14, 2011 7:12 am
And still loads of flex yet.. Mind the massive offset rims on it to!! haha
Post Posted: Mon Feb 14, 2011 7:14 am
Firstly i'm in love with the look of that. And any pics of it on flat ground?
Also hope you had extended brake lines.
Post Posted: Mon Feb 14, 2011 7:18 am
only one. but this is with only the TD lift kit and massive offset rims not the lift.
And this is with just the front done I think. Not 100% sure and sorry about the dodgy quality.
Users browsing this forum: No registered users and 393 guests
