It is currently Thu Nov 05, 2026 7:40 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3
Post Posted: Tue Sep 20, 2011 12:50 am
I like the idea of air dams between grille and radiator to get all the air coming through the grille to go through the radiator if you cant sjut fit a wider one
I have done this, top, bottom and both sides, sides are wider and force more air towards the radiator.
IMO its a must no matter you use a clutch fan or thermo.
More air, more better.
Post Posted: Tue Sep 20, 2011 12:53 am
yep, royce is on the money.
on one of my mk1 cortina's with a worked motor it only ran a pissy 2 blade unshrouded mechanical fan which was enough for sitting in traffic & around town. dad had fabbed up 2 alloy ducts/shields either side of the radiator filling the gaps from the inner guards to radiator which channelled air into the radiator at speed. it was that effective you could run the car for hours at highway speed with no fan, just the water pump & force fed air.
it was that effective on a 42+ degree day fuel would start vapourising due to under bonnet temps before it even came close to getting warm.
i've done similar sort of thing to my vitara once bodylifted there were gaps everywhere around the radiator & either side of the engine bay, my thoughts are the factory have put countless hours in getting air to pass thru the radiator & out & under the footwells/trans tunnel, i filled the gaps around the radiator with thin rubber sheeting, above the radiator/rad support panel & the front section of the engine bay to the strut tower trying to replicate the original air flow path from the factory.
Vehicle: LPG 1.6 Sierra
Post Posted: Tue Sep 20, 2011 8:29 am
Is it just the pic, or are the blades on the vit fan spaced unevenly? Looks not quite right.
Post Posted: Tue Sep 20, 2011 8:44 am
yeah vit fans are wonky looking
Vehicle: Zookless
Post Posted: Tue Dec 06, 2011 8:26 am
I just installed a Vit fan today. Nice and easy. :)
All I had to do was slightly round out the drivers side holes on the shroud, so I could move it over slightly. Other than that, perfect fit!
Here's the fit fan on left, with my old Sierra fan after it met some water on the Balfour Track :lol:
Users browsing this forum: Google [Bot] and 50 guests
