It is currently Fri Oct 02, 2026 12:49 am
Post new topic Reply to topic  [ 215 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
Post Posted: Fri Oct 14, 2011 2:44 am
ok lets assume vibrations made something break
normally vibrations make things come loose, so maybe run around and check all the ecu lugs are in solid and all the loom plugs are tight
look for loose or missing earths as well, maybe even loose or missing fuses, you should have a sold one from engine to battery and engine to body as aminimum
something that I noticed you said before was when you checked the map sensor you said there were 2 pins with power and 1 with signal, now I dont have a diagram to check but generally there will be an earth cable as one of those 3 that should read 0 volts, that might indicate an earth that has come off
Post Posted: Fri Oct 14, 2011 2:46 am
Then check all connections to and from the ECU and sensors/batt etc. Disassemble and reassemble, clean if needed. Give all wires a firm tug to see if they are still holding in there properly.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri Oct 14, 2011 2:47 am
o
And this too!
Lil Foot!
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Oct 14, 2011 2:51 am
Has to be a blockage in the fuel system somewhere you'd think. Maybe the corrugations stirred up some shit in the fuel tank and it's got itself blocked somewhere? Just a thought, prob way off the mark lol
thats the map circuit
MY BUILD THREAD HERE!!!!!
Post Posted: Fri Oct 14, 2011 2:54 am
yeah i thought about blockage also, i might disconnect and try blowing out the system or something
Post Posted: Fri Oct 14, 2011 2:55 am
should read
5v on Lg/R
0v on B/Bl
G will swing with differing vacuum, I would assume it would be highest with teh engine not running and lower at idle, rising when you open the throttle and lowering when you back off
Post Posted: Fri Oct 14, 2011 2:57 am
That's what the idea behind removing the vac line off the fuel reg, to make higher fuel pressure/rich situation. Apparently made no difference to the issue
Lil Foot!
Post Posted: Fri Oct 14, 2011 3:11 am
[flash width=480 height=385]http://www.youtube-nocookie.com/v/ugErAz5R-AY.swf[/flash]
heres what it sounds like at the moment
note the hard starting, and the terrible starter motor noise.
http://www.youtube.com/watch?v=ugErAz5R-AY
Post Posted: Fri Oct 14, 2011 3:16 am
so it misses when you hit the throttle or at least bogs big time?
can you slowly raise the revs up and get it to hold at higher revs?
Post Posted: Fri Oct 14, 2011 3:18 am
This and open the intake above the throttle body and spray something like wd40 down there and see if it picks up. That could determine a fueling issue
Lil Foot!
Post Posted: Fri Oct 14, 2011 3:21 am
i cant slowly bring it up, i tried in the vid to do that. originally i sorta was able to when i limped it home (could never get above 3.5-4krpm), but it got too bad and had to tow.
is wd40 acceptable for this? or should i get something like start ya bastard
Post Posted: Fri Oct 14, 2011 3:23 am
wd40 will burn nice and good :)
Post Posted: Fri Oct 14, 2011 3:25 am
And its a lot more stable than the 20% either that's in start ya bastard :D
Lil Foot!
Post Posted: Fri Oct 14, 2011 3:35 am
ill give it a go in a bit, just taking a break.
shit my wd40 is empty, just asked the girly to get me some on way home, ill make a vid when i do it.
Post Posted: Fri Oct 14, 2011 4:05 am
What about yacam sensor, just a thought
Post Posted: Fri Oct 14, 2011 4:27 am
Scales wrote:
Ok just a rundown of where im at
removed cam sensor whilst running, gets worse, refitted
tried that
Post Posted: Fri Oct 14, 2011 5:03 am
Did you say the map sensor has a crack in it?
Post Posted: Fri Oct 14, 2011 5:07 am
i just had a look down the throttle body, there seems to be a bit of bulldust down there. seems i have had a bit of a leak in one of the airbox hoses......
yes a small crack in the map sensor, i dont think its ruined it however.
Post Posted: Fri Oct 14, 2011 5:10 am
Hurry up and clean it so we can all find out if this is the problem!!!! :crazy:
Post Posted: Fri Oct 14, 2011 5:16 am
you'd almost be ready to shep it by now. 8O
Post Posted: Fri Oct 14, 2011 5:18 am
im going to take the whole throttle body off tomorrow and clean it out. also going to put some oil flush in and do a change (was due anyway) hopefully that makes a difference.
btw i did the wd40 thing, it didnt do anything. I was able to bring the revs right up with slight throttle however.
Shep it???? pls explain?
How much dust got past the air filter by the way?
Lil Foot!
Post Posted: Fri Oct 14, 2011 5:19 am
well the MAP sensor is what senses the amount of air the engine is taking in, it is how the ECM determines the amount of fuel to add.
If there is a crack in the map sensor that lets air leak, then the ECM is going to assume it is not sucking as much air, so it will pull fuel out (reduce fuel)accordingly.
Anyone have a MAP sensor you can borrow for a few minutes?
Post Posted: Fri Oct 14, 2011 5:20 am
have no idea how much got past. could have been a hell of a lot, to next to none, how would u measure such a thing?????????
there was a thin layer of red dust in there, thats all i know
Post Posted: Fri Oct 14, 2011 5:38 am
dont know anyone with a jim up here to borrow a map.
anyone know where i can get an aftermarket one?
Post Posted: Fri Oct 14, 2011 5:39 am
should read
5v on Lg/R
0v on B/Bl
Recheck this as royce has suggested to check if the MAP is working how it should be
Lil Foot!
Post Posted: Fri Oct 14, 2011 5:40 am
dust in the manifold I would be doing a compression test :(
Post Posted: Fri Oct 14, 2011 5:45 am
Is the exhaust connected again?
Have you ruled out the muffler?
I read that you ran it with cat-back disconnected and seemed no different but maybe with it disconnected there was no back-pressure causing poor running, and with it connected the muffler blocks the flow. If you haven't already done so, give the muffler a firm bash a few times with your palm and listen for movement inside. If you hear stuff inside then I'd say you may have found at least another part of your problem.
My old Jim had the same symptoms. Backfiring or in this case serious vibrations can shatter the innards of the cat and then it gets blown into the muffler where it will stay forever. Mine had backfired due to a faulty crank angle sensor, then weeks later it started loosing power half way through a two hour road trip and by the time we arrived at the destination it could barely crawl in first. Gave it fair few bashes when I found the problem and luckily managed to dislodge it a bit so I could get home.
Vehicle: 4wd
Post Posted: Fri Oct 14, 2011 6:35 am
Scales wrote:
havent done that with the injectors yet. theyre on my list though, spark plugs are a-ok, just pulled them again
checked plugs, look dry to me. they are sealed up quite well actually.
wheres this earth your talking about?
also checked voltages on the map, seem ok. 5v, sig and another 5v. pretty much what the manual calls for i believe
Did you find the earth?
Watch out or you'll get sued.
Users browsing this forum: Google [Bot] and 159 guests
