It is currently Tue Oct 13, 2026 1:51 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3
Post Posted: Sun May 18, 2014 6:49 am
Rustyray13 wrote:
Lol wish i had chrome shocks
If you're referring to the coil sierra photo that Jim_Aus posted, they're not chrome shocks, they're airshocks.
Heavily inclined, inboard air shocks+no swaybar+no roll stiffness from the suspension=massive flops
+no springs, I wonder how much testing its had.
Vehicle: Suzuki Jimny 2010
Post Posted: Sun May 18, 2014 9:08 am
Rustyray13 wrote:
Lol wish i had chrome shocks, so my jb arms turned up they look pretty good theyre heavier than i thought very solid construction. i price genuine rubber bushes(12) from penrith suzuki will have to rder them in $546.00 priced jb rubber ones delivered $655.00 what is everyone else running id prefer rubber and whatd you pay
Pm Bruce and get his bushes. I'm using them in my ORA arms. The rubber ones were splitting after every two or so trips. I'm not going to put his price up just incase I'm wrong, but he is MUCH! Cheaper than 5-600
Post Posted: Sun May 18, 2014 10:19 am
rubber ones are just getting good when they start to split ;)
Post Posted: Sun May 18, 2014 5:11 pm
The air shocks are the spring essentially.
Post Posted: Mon May 19, 2014 1:05 pm
yea i should have looked at the pic closer.....
Vehicle: jimny
Post Posted: Sat May 24, 2014 7:01 pm
So got mu jb front and rear arms last weekend and a full set of rubber bushes during the week. the 12 bushes turned out to all be identical chasis end bushes (65mm wide as opposed to axle end whuch shouldve been 60mm wide crush tube section) i pressed in all the bushes at work with a small 150t press not realising the axle bushes were wrong just pressed them in with even protrusion each side of the arms. jacked up the truck today and did the big swap and found out the front bushes dont fit in so ground them down to 60mm fitted all anyway. the bushes dont fouk at full flex so all good in the end. im pretty happy with the jb arms they are heaps more heavy duty than i expected and gained clearance unde the arms compared to stock. the front springs are more straight but still not perfect but its too late to change now the rear arms are slightly shorter than stock which was a suprise but they work well no fouling of the 30x9.5s
Post Posted: Sat May 24, 2014 7:13 pm
Surprising that the rear arms are shorter than stock
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat May 24, 2014 7:52 pm
you could have used the bushes out of your old arms and ordered in the correct bushes instead of chopping them, if you wanted
Vehicle: jimny
Post Posted: Sun May 25, 2014 7:03 am
Bushes in old arms wer poly castor corrected ones ill swap them to correct ones if they prove to be a problem
Users browsing this forum: Google [Bot] and 146 guests
