It is currently Sat Sep 19, 2026 11:16 pm
Post new topic Reply to topic  [ 1017 posts ]  Go to page Previous  1 ... 26, 27, 28, 29, 30, 31, 32 ... 34  Next
Vehicle: Suzuki jimny 2002
Post Posted: Sun Nov 30, 2014 3:32 pm
Hi Everyone,I was looking at putting new boots on my 2002 jimny to replace the 205/70 15 on it now.I would liked to have got some 215/75 15 BFG A/T for it but when I went to order some from my local T-mart,there told me that there are none in Australia,and wont be until at least march next year! They also told me that they are an"odd size" so may not be available anyway.I did point out that the BFG A/T in 215/75 15 are listed in their christmas catalogue! So if your looking for BFG's in any size or pattern,you will have to wait or find something else.Just thought you would like to know.
Vehicle: Vitara 1994
Post Posted: Sun Nov 30, 2014 4:35 pm
Makes sense BFG are coming out with a new AT so might take some time for it to get to the stores
Vehicle: SJ70 1993
Post Posted: Thu Dec 04, 2014 11:24 am
How are light truck tyres in regards high way driving for zooks? like the 8.25xR16?
http://www.tyreandtubeaust.com.au/8-25r ... -boto-set/
Or others like that? just been looking for a skinny road purpose tyre at 32-33"
Vehicle: Which one?
Post Posted: Thu Dec 04, 2014 11:54 am
I think the general consensus is that the heavy duty sidewalls in light truck tyres make zooks ride like absolute rubbish.
235/85R16 is probably a better size and available in oodles of different brands and tread patterns with far softer sidewalls.
Vehicle: SJ70 1993
Post Posted: Thu Dec 04, 2014 11:56 am
Yeah being light truck I figured the would be heavy side wall,
Cheers thou
Post Posted: Thu Dec 04, 2014 12:25 pm
The 8.25's I've seen have had stratospheric load ratings and are crazy crazy heavy. I wouldn't run them on a sierra.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Dec 04, 2014 12:35 pm
i blame my rear shocks, but the 30x9.5 lt's may be to blame.
Post Posted: Thu Dec 04, 2014 1:42 pm
I had 6.50x16 truck tyres on my Sierra and it sucked.
Post Posted: Thu Dec 11, 2014 8:41 am
What tires come in 255 85 16
Km2
Toyo open country mt
Creepy crawlers
Big horns
Post Posted: Thu Dec 11, 2014 8:45 am
Not aware of any others.
Post Posted: Thu Dec 11, 2014 9:08 am
Do u think the toyo would be to heavy for a gv
They have good looking side walls
Any one know if u Can weld beadlocks to stock gv rims and change offset
Post Posted: Thu Dec 11, 2014 9:15 am
A) no idea. Toyo seem to be producing pretty good tyres though.
B) no. The design of the rim prevents a weld on beadlock being fitted. Offset changes are also difficult without throwing the rim away and just retaining the centre.
Post Posted: Thu Dec 11, 2014 9:19 am
Know any rims that clear gv calipers
Post Posted: Thu Dec 11, 2014 9:22 am
17" maybe?
Post Posted: Sat Dec 13, 2014 3:40 am
The 35x12.50r16 trepador comps in the standard compound just arrived in the UK so I'm guessing your local maxxis dealers should be able to get them as well?
Vehicle: 99 Grand Vitara
Post Posted: Sat Dec 13, 2014 9:24 am
Think Ninjamoses is the only one to find a rim that clears the lwb calipers. SWB j20a can fit 16x7 -12 Sunnys and the 1.6 can fit 15s I believe. Can make 16x7 Sunnys if you grind the calipers to clear.
Km2
Creepy crawlers
Big horns
Ill defs be going the km2s, heard good things about them and also lighter than the toyos by 3kg.
http://www.strictly4x4.com.au
Vehicle: Which one?
Post Posted: Sat Dec 13, 2014 12:05 pm
Yeah it can 8)
Post Posted: Sat Dec 13, 2014 12:18 pm
henno wrote:
Yeah it can 8)
next time you have a front wheel off, can you grab a pic of the caliper & caliper mount & throw it in the soup kitchen? 8)
maybe they fitted SV brakes on the SQ420's, don't happen to know the brake pad number? :?
Vehicle: Which one?
Post Posted: Sat Dec 13, 2014 1:22 pm
Here's something I prepared earlier:
Vehicle: Which one?
Post Posted: Sat Dec 13, 2014 1:26 pm
Yours look very different:
Post Posted: Sat Dec 13, 2014 1:29 pm
bloody hell suzuki, talk about chopping & changing.
back to tyres. :oops:
Post Posted: Sat Dec 13, 2014 7:21 pm
I would have to trailer it to run 35 and I want to be able to drive to other states if I need to
And they would destroy drive line
Post Posted: Sun Dec 14, 2014 9:15 am
Sorry that wasnt aimed at anyone in particular, I just remembered the 35" comp treps were mentioned earlier in this thread and quite a few people sounded interested, wondering if and when they were going to be available in other countries. So thought I'd post up that we now have them in the UK and I would presume that maxxis dealers would also be able to get them in Australia for anyone that might be interested.
Post Posted: Wed Dec 17, 2014 12:34 am
I like 255/85R16 as a size - works great on a Range Rover Classic.
An alternative is 33x9.5R16 Silverstone MT117 Extreme - cheap & work even better in mud.
Also 33x10.5R15 is available from BFG & Maxis, but 15" rims don't fit over SQ625 front brakes
A 33" tyre on a GV is a big ask, but has been done (body lift)
The next tyres I buy for my GV will be 215/85R16 on modded std steel wheel centres with a 6.5" rim to give a bit more offest & chassis clearance.
Not a great range of tyres, but something like Hankook Dynapro MT would have to give me benefit over the BFG A/T KO's I currently run.
Rgs, Michael
Post Posted: Wed Dec 17, 2014 10:26 am
The ifs toy has 35 no body lift and only 2in lift so 33 on 4in lift should be ok with 3-4 bump stop spacing. From what ive seen on the net the 255 85 16 are almost as big as 35 km2 which are only like 33.75 " tall. Most brand measure bigger then 33in
From what ive seen Silverstones are a pretty crap tire. There even worse then simex and they are pretty bad on anything other then mud. Mate sold his 35 after like a month they were that bad .
Vehicle: Which one?
Post Posted: Wed Dec 17, 2014 11:49 am
There'd be a fairly big difference in width though; something in the range of 2-2.5"?
Post Posted: Wed Dec 17, 2014 1:52 pm
BFG lists the 255/85R16 at 33.3", the 315/75R16 at 34.8"?
I'm running the 32s on stock bumpstops with no scrubbing. I do suspect when I go 255s they will rub on the inner guard on full compression. Front should be ok.
Post Posted: Wed Dec 17, 2014 8:05 pm
Mate has 35x12.5 15 km2 and they measure under 34. He was pretty pissed about it
Vehicle: 04 Grand Vitara, 2.5L, V6
Post Posted: Wed Dec 17, 2014 10:35 pm
Seems to be a trend 225/75/16 kl71 are just over 27in new...
Vehicle: Which one?
Post Posted: Thu Dec 18, 2014 7:10 am
Eh? Mine were a bee's dick short of 30" :?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 188 guests
