It is currently Sun Sep 20, 2026 6:49 pm
Post new topic Reply to topic  [ 1017 posts ]  Go to page Previous  1 ... 29, 30, 31, 32, 33, 34  Next
Vehicle: sj80
Post Posted: Mon Jul 04, 2016 11:11 pm
The SRL isn't in the size I'm looking for (225/75R16).
I can get BFG Continental Michelins Goodyear Dunlop Hankooks and Kumho all at cost price.
Fair amount of highway use, moderate off-roading, but tbh, I want something that looks the biz, handles offroad, and also won't get my killed heading to CBD or going for a drive to the coast.
Any suggestions?
And I don't know why, but the coopers just do it for me, look the biz, awesome technology, and not made in asia!!
Edit: Best tyre review i've read
Post Posted: Tue Jul 05, 2016 5:59 am
Hankook dynapro mt best tyre ive had for offroad durability, super quiet for a muddie onroad and longevity
Post Posted: Tue Jul 05, 2016 6:52 am
You can get BFG or Goodyear at cost and you still want coopers? Hmmokay
Vehicle: sierra
Post Posted: Tue Jul 05, 2016 5:25 pm
I just bolted KM2s on my Sierra. So far so good! They grip pretty well to.
Post Posted: Wed Apr 03, 2019 10:28 pm
Winter is coming, and I've just got a new job with weekends back Armsup the GV will be getting tires and new job means its also not going to be a daily for a little while Armsup Armsup
I'm after a reasonably aggressive mud tire that still lets me drive the 3hours+ up to the high country.
Current options are...
$150ish cumforcer/federal/powertrac/whatever is on special that has been most recently imported.
Or
$300ish KM2/Dynapro MT/safari TSR (are these really almost twice the tire the cheap ones are?)
Still unsure which way to go.
I also haven't decided on sizing, 245/75/16 will fit easy enough, but is a little wider than I'd like.
215/85/16 I think is perfect, but don't seem to be on anyone's website as being brought in to the country.
235/85/16 Likely too big just from an axle strength vs my laziness to be constantly working on it.
What are peoples thoughts?
Vehicle: LJ50V, SJ70
Post Posted: Wed Apr 03, 2019 11:34 pm
Or
$300ish KM2 (are these really almost twice the tire the cheap ones are?)
KM2: https://www.ebay.com.au/itm/BF-GOODRICH ... ctupt=true
KM3: https://www.ebay.com.au/itm/4x-LT-235-7 ... ctupt=true
Post Posted: Thu Apr 04, 2019 1:14 am
I had cumforcers on my ute was pretty fucked on the road wear was shithouse but were pretty good offroad.
Km2 are quite skinny for a 245.
Post Posted: Thu Apr 04, 2019 7:54 pm
303zuke wrote:
Or
245/75/16 seems to ad a premium. $260 is the cheapest I can find locally for a km2 and $295 for KM3.
Thanks, good to know.
Seriously tempted by them for no other reason than they look cool.
Post Posted: Sat Apr 06, 2019 11:08 pm
Got BFG km2 in 245/75R16 on my SQ625 GV.
Daily driven & run nicely for a M/T.
245 fit with a bit of work. Chassis rub at the back of the front wheels on lock is an issue.
I don't have lots of lift in mine & had to stuff around with both front & rear wheel arches.
Like you, I think a 215/85R16 would be the best fit, but a rare size in a M/T.
Rgs, Michael
Vehicle: JB32
Post Posted: Fri Nov 22, 2019 7:56 pm
Hey there big brains, going through the steps of getting brakes engineered and was shocked that the engineer said that it was impossible to ever get a wheel certified if it was more than 50mm larger. From reading the VSB I'm shocked to see that maybe he was right, but I'm still in denial. Anybody have any more insight, should I look for another engineer or he was right?
And tying into that, what was the largest factory tyre for an SJ80?
I feel like somebody said that we might be able to get our base height from the largest tyre fitted to our axle / spindle ?
Post Posted: Sat Nov 23, 2019 7:17 am
The largest factory tyre on an SJ80 is what they were delivered with locally. 26"
No, you can't get over a 7" rim engineered on a Sierra, not would you want to - no tyre that requires an 8" rim could be engineered on a Sierra, and no tyre that requires an 8" rim will really work effectively anyway.
You might be able to cheat another inch of tyre diameter in the front because the SJ80 uses the spindle and bearing from a Vitara, and if you can convince the engineer that the rear wheel bearing is the same as those used on a Sierra with 16" rims, that will give you a bit of leeway in the rear.
It won't increase permissible rim width, because the widest Sierra rim was only ever 5"
Post Posted: Wed Jul 15, 2020 10:22 pm
Am I crazy for wanting to run a 215/85r16 LT on my NGV such as these, they're a good size (30.4/8.5r16) but are a true LT construction.
https://tiresize.com/tires/Toyo/Open-Co ... -85R16.htm
Vehicle: Vitara 1994
Post Posted: Wed Jul 15, 2020 11:13 pm
I ran 215/80R15's on the Jimny and loved them, however they were a true SL rated tire and very light all terrain. They deformed awesome over rocks and almost tok capable in sand
Sent from my SM-N960N using Tapatalk
Post Posted: Thu Jul 16, 2020 12:06 am
Do it! How much taller then standard are they?
Post Posted: Thu Jul 16, 2020 8:52 am
28.6” vs 30.4” or 46mm taller than stock, they’re the largest diameter that will fit. It’s a skinny version of the 245/75r16 that everyone runs
Post Posted: Thu Jul 16, 2020 9:45 am
I would expect a 215/80 to outperform a 245 in most off road situations. Interestingly when I joined the Vic suzuki club in 1993, there were a couple of kiwis in the club that swore by 215 80, and ran them on their big cars. I’d never seen them up to that point and have basically never seen them since. Good find though, assuming you can get the construction/tread pattern you’re looking for.
Post Posted: Thu Jul 16, 2020 11:59 am
This is the specs on the Toyo Open Country, my only concern is the load rating & all of the tyres in that size have a huge load rating.
Diameter : 30.4”
Width : 8.5”
Rim Range : 5.5-7”
Measured Rim : 6”
Tread Depth : 15.8/32”
Load Range : E - 10 ply
Max Load : 2680/2470 lbs
Max psi : 80 psi
Max Speed : 99 mph
Weight : 39 lbs
Post Posted: Fri Jul 17, 2020 3:23 pm
Diameter : 30.4”
Width : 8.5”
Rim Range : 5.5-7”
Measured Rim : 6”
Max psi : 80 psi
Max Speed : 99 mph
Weight : 39 lbs
Are these going to be hard as a rock? :-?
Post Posted: Fri Jul 17, 2020 5:44 pm
Most likely
Post Posted: Fri Jul 17, 2020 8:10 pm
Most likely
This is where I get confused, the low profile 235/60r18 cross terrains are XL rated & have a max load of 2150lbs.
Surely the 215/85r16 with a load rating of 2460lb won’t be Much worse than the rubber bands that are currently on it.
Post Posted: Fri Jul 17, 2020 8:15 pm
Toyo seem obsessed with long life though, so they seem to make their tyres from carbonite.
Post Posted: Fri Jul 17, 2020 8:23 pm
Even the Goodyear duratrac in 215/85r16 have a high load rating & the E-10 ply rating.
Post Posted: Fri Jul 17, 2020 8:24 pm
Looking at all the options in that size they all have the E-10 ply rating & high load ratings
Post Posted: Fri Jul 17, 2020 9:42 pm
This size, while I think ideal for a Suzuki application, is rare in the Aust. market. Much more common in the USA - even a factory size on some mid-size SUVs (well, it was when I researched these things years ago).
Because they are on these mid-size SUVs, the load rating reflects the much heavier than Suzuki weights they might be called on to support.
So while size is good, availibility / range is poor & carcass weight / ply rating is high.
Which is why I run 245/75R16 - same O.D but a little wider, but then my car is a heavy arse GV SQ625.
Rgs, Michael
Post Posted: Fri Jul 17, 2020 10:13 pm
I don’t like the way my NGV drives on a 235/60r18 vs the stock 225/60r18 & going up to a 245 seems counterproductive. I have no issues importing tyres. My current 235/60r18 cross terrains came out of the states due to lack of available options here.
Post Posted: Tue Jul 21, 2020 10:15 am
Diameter : 30.4”
Width : 8.5”
Rim Range : 5.5-7”
Measured Rim : 6”
Max psi : 80 psi
Max Speed : 99 mph
Weight : 39 lbs
The two things i dont like about them are the stiffness and the extra weight. When i searched for my tall and skinny's i managed to find SL rating (despite actully being able to carry more than the LT equivalent) that was light and deformed amazing. With the non agressive AT pattern I ran the the sipping a ability to deform is what made the tire capable.
Problem is in the size you want they will all be hard as rock with a lot of plys as they are tires designed for the duel real wheel 1 ton trucks in the states.
Post Posted: Tue Jul 21, 2020 10:18 am
Going down to a 16 inch wheel shohld help a lot as there is a lot more side wall to move around so less will be transfered tonthe sterring. Even in tge same thickness
Post Posted: Tue Jul 21, 2020 2:21 pm
Diameter : 30.4”
Width : 8.5”
Rim Range : 5.5-7”
Measured Rim : 6”
Max psi : 80 psi
Max Speed : 99 mph
Weight : 39 lbs
I've been cross referencing the shit out of tyre specs the last couple of days, and I don't think it's going to be as bad as everyone make it out to be.
As an example I was checking the specs above to a BFG Ko2 in a 245/75r16 & the Ko2 in the common maximum size that people put on NGV's has higher load rating & the same ply rating as the 215/85r16, the 245/75r16 weighs 21.9 kg vs 17kgs for the 215/85r16.
Diameter : 30.4"
Width : 9.8"
Rim Range : 6.5-8"
Measured Rim : 7"
Tread Depth : 15/32"
Max Load : 3042/2778 lbs
Max psi : 80 psi
Max Speed : 112 mph
Weight : 48.4 lbs
The Ko2 only come in one spec in 245/75r16
LT245/75R16
120/116S E RWL
Post Posted: Tue Jul 21, 2020 4:54 pm
I hope your ordering 7 tyres so you have the same on the camper :lol:
Post Posted: Tue Jul 21, 2020 5:10 pm
you should see the big gay chrome wheels i bought. :blingbling: pompoms rodney jane specials pompoms :blingbling:
Users browsing this forum: No registered users and 134 guests
