| Author |
Message |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Mon Aug 23, 2021 2:16 pm |
I have one 35" Roxzilla mounted. The rims will be beadlocked, but I needed to know I was int the ballpark with clearance and stance before I cut and welded more rims. at 18 psi, it sits 34" tall laden   As discussed, they do crown. Treps do this too, but they're cross plies. I've never seen a radial crown like this. This is also true of the "hard" 32's
Gwagensteve
 Posted: Mon Aug 23, 2021 2:18 pm |
They also feel insanely light compared to the Krawler/Walker combo. I know they'll get 3.8Kg per corner heavier with the beadlocks fitted, but they're much more manageable.
30ONA
 Posted: Tue Aug 24, 2021 11:48 am |
Is there a tolerance for tyres being out of round from new? My car bounces and wobbles at low traffic speeds and presumably high speeds to but not noticeable. I jacked the car and you can see about 3mm out of round on each tyre. They are Toyo open country with about 20,000 and all even wear.
Gwagensteve
 Posted: Tue Aug 24, 2021 12:00 pm |
Samrix253
Vehicle: Suzuki sierra
 Posted: Mon Jan 03, 2022 8:10 pm |
Is there anyone running Badak Xtremes in Aus? I’m looking at sourcing a set for mine and seeking some reviews on it. And are there any Australian distributors that stock the 31”? https://acceleratire.com/tires/badak-x-treme/
_________________ Project Shitbox @zooker4x4
Samrix253
 Posted: Mon Jan 03, 2022 8:28 pm |
Gwagensteve
 Posted: Fri Jan 07, 2022 12:02 pm |
They're an interesting tyre but I haven't heard of anyone running them on a Sierra.
They key will be how heavy and stiff they are.
Beery
Vehicle: suzuki sj50
 Posted: Sat Feb 19, 2022 1:11 pm |
Ok, so with everyone getting on the UTV/SXS tyre train, it's got me interested. I was out to dinner last night with a mate who works at a local bike shop but also works on SXS's etc etc… he was adamant he could source any tyre that Maxxis in particular makes (this is yet to be confirmed but got me a bit excited) so I got searching. I'm aware the roxxzilla seems to be the pick of the bunch, however the smallest tyre available in a 15 inch rim is a 32, which measures closer to a 33 in the real world from what I gather. I'm more interested in a smaller tyre for now, something around 30 inch, for a few reasons: Gearing, driveline reliability, cop bait and the effort involved to fit them. To get a tyre this size, most require a 14 inch rim and I can't find anything suitable for a sierra. It was suggested to me I could make a 14 inch rim - weld a sierra stud pattern centre into a 14 inch outer, but mehh, I'm not thrilled on the idea and it's a shedload of work. I also couldn't find any weld on bead lock kits suitable for a 14 inch rim. Bfg do the KR2 in a 30x9.5r15, which would be ideal I think but they are very expensive and I only know of one importer, so add freight to that to get them at my door. In my searches I found these - maxxis liberty: https://www.maxxis.com/int/tire/liberty/  Available in a 29x9.5r15, however is does say the overall diameter is 29.7, so may be closer to a 30 once mounted. From what I can tell they are from the same family as the roxxzilla, I'm going to assume they are of similar compound as the "hard" spec, with less aggressive tread pattern. I'm quite impressed with my current federals in muddy conditions but on anything else, especially rock, I think there is a lot of room for improvement, although it's hard for me to tell, I've never run anything else off road. Keen to hear some thoughts, unless I'm missing something here, I think they could be a good option.
vet 180
Vehicle: Vitara 1994
 Posted: Sat Feb 19, 2022 9:00 pm |
Beery wrote: Ok, so with everyone getting on the UTV/SXS tyre train, it's got me interested. I was out to dinner last night with a mate who works at a local bike shop but also works on SXS's etc etc… he was adamant he could source any tyre that Maxxis in particular makes (this is yet to be confirmed but got me a bit excited) so I got searching. I'm aware the roxxzilla seems to be the pick of the bunch, however the smallest tyre available in a 15 inch rim is a 32, which measures closer to a 33 in the real world from what I gather. I'm more interested in a smaller tyre for now, something around 30 inch, for a few reasons: Gearing, driveline reliability, cop bait and the effort involved to fit them. To get a tyre this size, most require a 14 inch rim and I can't find anything suitable for a sierra. It was suggested to me I could make a 14 inch rim - weld a sierra stud pattern centre into a 14 inch outer, but mehh, I'm not thrilled on the idea and it's a shedload of work. I also couldn't find any weld on bead lock kits suitable for a 14 inch rim. Bfg do the KR2 in a 30x9.5r15, which would be ideal I think but they are very expensive and I only know of one importer, so add freight to that to get them at my door. In my searches I found these - maxxis liberty: https://www.maxxis.com/int/tire/liberty/  Available in a 29x9.5r15, however is does say the overall diameter is 29.7, so may be closer to a 30 once mounted. From what I can tell they are from the same family as the roxxzilla, I'm going to assume they are of similar compound as the "hard" spec, with less aggressive tread pattern. I'm quite impressed with my current federals in muddy conditions but on anything else, especially rock, I think there is a lot of room for improvement, although it's hard for me to tell, I've never run anything else off road. Keen to hear some thoughts, unless I'm missing something here, I think they could be a good option. If i could get anything from Maxxis i would go a set of GV wheels and go these is a heart beat. As long as you are not afraid of bias ply.    Sent from my SM-N960F using Tapatalk
rpmwrx
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1303 Location: Geelong
 Posted: Sat Feb 19, 2022 9:48 pm |
Samrix253 wrote: Anyone running Badak Xtremes? I’m looking at sourcing some from an Australian supplier if anyone knows of one. https://acceleratire.com/tires/badak-x-treme/G & S Tyres in Melbourne imports these tyres. I hope that helps.
Beery
 Posted: Sat Feb 19, 2022 11:42 pm |
vet 180 wrote: If i could get anything from Maxxis i would go a set of GV wheels and go these is a heart beat. As long as you are not afraid of bias ply. Why would you get these over the liberty's though? I remember seeing jono(?) on here have success with the creepy's, but I think that was a while ago, I'm wondering if there is better available nowadays. I'd have to do more research into them, but right off the bat, being a 16 inch (higher load ratings) and designed for a heavier car, aren't strong points compared to the liberty. I'm not really sure what you mean when you say afraid of a bias ply, to be honest I'm not to knowledgeable on bias vs radial, I'm aware of the construction differences but I'm not too sure what this means in the real world, I'll look into it more.
Gwagensteve
 Posted: Mon Feb 21, 2022 7:15 am |
I don't have any direct experience with the 7.00 Maxxis, Jon165 ran 255 85 16's. They worked very, very well. They did tend to burp the inner bead a bit but that may have been down to the rims (Gecko beadlocks)  They did bag, as you can see in this photo. The big reason for running creepy's over a UTV tyre is a creepy is speed and load rated and doesn't have N.H.S on the sidewall. I think this is especially true for a 30" tyre which is basically legalish if speed and load rated. Once you're running a 35 or something it's not legal, load rated or not. My preference has always been bias ply for off road cars as the tread is more flexible than on an LT radial. Race/UTV radials are a different ball game though.
Beery
 Posted: Mon Feb 21, 2022 9:27 am |
Okay, good to know.
Interestingly, the liberty's have been DOT rated, but i'm not sure if they're actually approved. I was able to zoom in on a sidewall of one and it did have NHS printed in bold letters on the sidewall - that might be a size related thing, i'll look into it more tonight.
Gwagensteve
 Posted: Mon Feb 21, 2022 9:51 am |
DOT* is meaningless in Australia on vehicles manufactured after 1973 - without the ADR approved "112/115 Q" type speed and load rating, the tyres aren't legal here.
It's the same reason swampers aren't legal here, even though they are DOT approved.
There is some trickery going on in the US with DOT approval on SXS tyres. In some US states, SXS's can be road registered and I assume they require DOT approved tyres to be considered for full registration. Also, there's something going on with, for example, Interco Tire, who are labelling some of their giant tyres as "SXS use only" to avoid having to go through DOT paperwork for tyres with 2.5" of tread depth etc. They are clearly not going on a SXS.
DOT approval does apply here for rims, not tyres.
DOT: US Department of Transport
Beery
 Posted: Mon Feb 21, 2022 10:18 am |
Well, that rules that out then. I wasn't overly concerned about legality due to the fact that a 29-30inch tyre Is still illegal anyway, (although much less obvious then a bigger tyre ) i figure if i'm ever in a situation where the right authorities are bending down to look at the sidewall, then I'm stuffed either way. Whether heavier penalties may apply for something like this, i'm unsure.
Brenno
Joined: Thu Apr 22, 2010 11:30 pm Posts: 1000 Location: Hobart
 Posted: Mon Feb 21, 2022 7:20 pm |
30 inch tyres are legal of you have a model that came with 16 inch rims. Or your engineer is happy to sign off considering everything else between the models are the same.
vet 180
 Posted: Tue Feb 22, 2022 9:03 am |
Beery wrote: vet 180 wrote: If i could get anything from Maxxis i would go a set of GV wheels and go these is a heart beat. As long as you are not afraid of bias ply. Why would you get these over the liberty's though? I remember seeing jono(?) on here have success with the creepy's, but I think that was a while ago, I'm wondering if there is better available nowadays. I'd have to do more research into them, but right off the bat, being a 16 inch (higher load ratings) and designed for a heavier car, aren't strong points compared to the liberty. I'm not really sure what you mean when you say afraid of a bias ply, to be honest I'm not to knowledgeable on bias vs radial, I'm aware of the construction differences but I'm not too sure what this means in the real world, I'll look into it more. Great width to height ratio, proven tread, light weight (not sure on the liberties but I wouldn't think they are much if any lighter than 14kg). I prefer bias ply for a lot of reasons, but balancing can be a pain. Sent from my SM-N960F using Tapatalk
Beery
 Posted: Tue Feb 22, 2022 7:37 pm |
Brenno wrote: 30 inch tyres are legal of you have a model that came with 16 inch rims. Or your engineer is happy to sign off considering everything else between the models are the same. This is true Brenno. These (whatever I end up with) are just for the hard top though which I'm not really interested in engineering currently (if I could even find an engineer willing to sign that off), it's just to much effort/cost for it i think. My tray back on the other hand will almost certainly be engineered whenever I get around to it. vet 180 wrote: Great width to height ratio, proven tread, light weight Agreed, I done a bit of looking last night a found a few examples in japan I think, they look like they have pretty awesome proportions for their size!
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Tue May 10, 2022 1:00 pm |
Time for tires on the wombat. (SE416 swb) the 31's are too big and old. and I've got too many other things I wanna buy before I attack the transfer gearing.
Currently has 15x6jj Roh somethings that I've measured around 0 offset. Also have plenty of GV rims about.
Thinking 30x9.5r15 or 245/75/16 depending on whats available. Has anyone had any luck with any of the smorgasboard of 'unbranded' tires that the market is being swamped with at the moment? Car is on 45 day club permit, and a bush pig. Only commute is to get there.
Option 2 in something that size is a KM2 which is around $400 extra for the set.
seanzook06
Vehicle: 1993 sj70 soft top
 Posted: Tue May 10, 2022 2:33 pm |
I have 245/75 kumho kl71s, not exactly an unbranded tyre, but they go great and I recommend them, I wasn't even aware they still made km2s
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Tue May 10, 2022 10:52 pm |
My Jimny had Hifly MT601s on it when I bought it. They've been a great tyre for me. Never had a puncture, don't chip on gravel. A bit noisy new but good once they wear in. I got about 40'000kms out them + what ever the previous owner did. I bought another set. Cheap at $180 each for a 235/75r15, probably cheaper in the city. They do a 245/75r16 too.
turbo510
Vehicle: Suzuki Sierra tray
 Posted: Wed May 11, 2022 8:17 am |
I'm running Comforser muddies on my ute.
It never sees the road but they are great on my steep block and were the cheapest available when I bought them.
Tiop
Vehicle: Sierra '90
 Posted: Sun Sep 04, 2022 12:10 pm |
Interesting to see how the roxzilla go Steve, they look good. stumble on the post after I found the roxzilla's online got me thinking, then old google search "roxzilla suzuki" brought me here for a look
DesmondTheDrover
Vehicle: 1985 Holden Drover 1.3litre
 Posted: Tue May 06, 2025 1:58 pm |
Hi all, I'm looking for new tyres, and have come across the Pirelli SCORPION MUD tyres, especially in 235/85r16. It looks like they have quite a small load index (108) , compared to most other competitors (120). Also quite an aggressive tread pattern. Wondering if anyone has had any experience with them. Cheers, Frank Attachment: Screenshot 2025-05-06 at 2.28.18 PM.png
sideways
 Posted: Wed May 07, 2025 9:18 am |
I was looking at those about 15 years ago because of the low load rating as you say. They were silly cheap then too, maybe $160 a tyre. They look a bit odd, the tread is quite a bit narrower than the section width of the tyre.
I never bought them, just surprised they still make them.
Gwagensteve
 Posted: Wed May 07, 2025 1:51 pm |
They do have an offset lug and a narrow tread width will favour a sierra.
DesmondTheDrover
 Posted: Thu May 08, 2025 11:48 am |
awesome thanks so much guys! its either between these and going all out on bfg's or yokahama geolander mt's, will need to do more saving for those ones though!
