It is currently Sat Nov 14, 2026 1:36 am
Post Posted: Mon Feb 22, 2010 1:00 pm
Hey guys, a mate of miine just bought an 85 hitop nt. He has an old set of hilux diffs sitten there and a set off 33"s
Question how hard will these be to fit up and has it been done before, SPOA maybe?
any pics would be great.
suspenion wise he is looking into a 5 inch calmini kit.
cheers guys.
http://www.youtube.com/watch?v=PZvFGpfWvVI
Post Posted: Mon Feb 22, 2010 1:16 pm
Hilux diffs, Most people use the original hilux spacing up front. Because the pumkin is bigger, where the WT spacing is, is where the hilux pumpkin is.. Nt will be worse.
33's will be ok on suzuki diffs. What brand? Different brands = different sizing.
I have heard 33's fit with no lift and spoa.
I have 33's spua, Possibly 1 - 2 " spring lift, 2" bl, front diff forward, rear diff rearward alittle, and abit of bashing. My Nankang 33'x12.5s are more like 32'x11. Wide ones give you more drama's also.
Whats future plans?
Post Posted: Mon Feb 22, 2010 4:31 pm
what are you trying to achieve by doing it.
you say you want spring over with a 5" lift kit!!!! even with a wider track it's going to want to lay down for a rest. it's way higher then you'd need.
Don't do it just cos you've got the bits sitting there. your better off spending money on things that will improve it for the driving you will be doing.
Post Posted: Mon Feb 22, 2010 4:53 pm
To fit them up, the simplest explaination without massive detais would be this,
move spring spacing on the NT to WT specs. This will allow the standard hilux diff to be bolted up in a SPOA.
for the rear, move the spring perch's in to match the NT width.
then you have steering, shocks, pinion angles, driveshafts and all the fidly stuff to work out.
weaves.
Vehicle: jimny
Post Posted: Mon Feb 22, 2010 6:53 pm
dont forget that you will have angle issues with the rear drive shaft, better off with a bundy rear
Post Posted: Tue Feb 23, 2010 12:29 am
Thanks guys heaps of good info already
The main reason i was asking was that he has the lux wheels and diffs sitting there doin nothin and because its a hitop i thought a nice wide track would make a bit more stable off road.
might just keep an eye out for some wide track diffs for a wide track conversion and get some nice offset sunnies, i think that would be easier.
has anybody ever done that yj jeep spring suspension kit off lowrangeoffroad in the states. if so how good is it, just chuckin around ideas what to do with his susupension.
thanks.
Post Posted: Tue Feb 23, 2010 12:41 am
A nice wide track does make it more stable... 10" of lift to achieve it though makes it less stable.
alot
thanks.
Never seen one done in aus, its a bit of a yank thing. RUF and OME rears in the back is proven and works sweet.
Post Posted: Tue Feb 23, 2010 12:42 pm
thanks for the help guys, i think we will leave the lux diffs alone for now.
Post Posted: Tue Feb 23, 2010 11:39 pm
how wide do you want to make it on suzy diifs
the bule one is standard nt the red one is wt diffs in a narrow track car and 70 mm backspaced rims. ohh yeah and 34's
Users browsing this forum: Google [Bot] and 64 guests
