It is currently Sat Nov 14, 2026 8:21 am
Vehicle: 98 Maruti
Post Posted: Mon Feb 22, 2010 5:37 pm
im looking for a longer pair of shocks for the rear of my swb GV since my raised 30mm pair are bottoming out with my 60mm lift.
i was thinking about using a pair of commodore shocks but im worried they might be to long for the 60mm lift and il have hassles with my spring dropping out.
also what model commodore shocks are they best to use?
cheers
Post Posted: Mon Feb 22, 2010 5:57 pm
Your shocks are bottoming out and you want longer ones??
I want my old sig back :(
Post Posted: Mon Feb 22, 2010 6:41 pm
tried bumpstop extensions? OME have a listing for bumpstop extensions on the GV's
i've used VL & VR commonwhore shocks & they are MASSIVE, i know on the vitara you will need to change the roll sleeve that is in the bottom of the shock as the comodore bolt hole is alot smaller.
top shock is VL commodore
middle shock is calmini
bottom shock is stock
Vehicle: 98 Maruti
Post Posted: Mon Feb 22, 2010 7:17 pm
sorry i think i got that mixed up, my bump stops are good just shocks are limiting flex.
would i have hassles running a VL shock with 60mm lift?
Post Posted: Mon Feb 22, 2010 7:24 pm
you might find that the spring could fall out...
Post Posted: Mon Feb 22, 2010 7:32 pm
yes, your coils will drop out. the extreme shocks are the same length as the calmini shocks and i pair them with a 3inch coil and a 25mm spacer so that the coil does not drop out.
when i was running 60mm i took out the ome and stuck in the dobinson shocks as they were 10mm longer, i then threw a large nut ontop of the shock tower then the mounts which dropped the lowest point by 12mm.
gain drop but loose up travel.
Vehicle: 98 Maruti
Post Posted: Mon Feb 22, 2010 8:20 pm
i was worried about the coils dropping out.
im running a 30mm extended dobsion shock now so i think il just live with it how it is.
thanks for the advice
Post Posted: Mon Feb 22, 2010 8:51 pm
ODA1 wrote:
yes, i sell cool zook stuff....
you have PM :wink:
Users browsing this forum: No registered users and 73 guests
