http://auszookers.com/forum/
Need some sugestions for extending my cab. Any panelbeaters
http://auszookers.com/forum/viewtopic.php?f=5&t=10048
Author:  squirezook [ Tue Feb 23, 2010 4:37 pm ]
Post subject:  Need some sugestions for extending my cab. Any panelbeaters
The problem with the standard tin top ute cab is the depth at the back see pic
as you can see no room for a decent seat. Can't fit anything behind either
Rear of cab is spot welded in so... What do u reckon?.. Drill out the spots and reverse the back of cab so it faces out instead of in. Or drill out the spots and move the cab back and weld in a piece of steel?
You can view larger img.. here
http://s924.photobucket.com/albums/ad85 ... b%20resto/
Author:  your_mum [ Tue Feb 23, 2010 5:25 pm ]
Post subject:  Re: Need some sugestions for extending my cab. Any panelbeat
sounds like a damn good idea.
I never liked those cabs 'coz they're SO tiny.
Author:  charlie_brown [ Tue Feb 23, 2010 5:35 pm ]
I've thought about exactly the same thing for my ute. I haven't actually done it so I can't give any useful advice, but let us all know how it goes.
Good luck.
Author:  MrRocky [ Tue Feb 23, 2010 7:06 pm ]
mine is a maruti and has a bit more room because of the fibreglass back, but even still its only just enough room for me to fit in gti seats.
Personally if going to that much effort i would try and add a bit more space for storage as well.
Author:  squirezook [ Tue Feb 23, 2010 7:59 pm ]
Yep know what you mean. I am thinking 100mm extension and down below tray height add some space for storage. Don't want to move the tray back too far. Is a short ute as it is.
Author:  Ridge [ Tue Feb 23, 2010 8:37 pm ]
i want a cab like this
the build link http://www.pirate4x4.com/forum/showthread.php?t=313024
Author:  steak_knife [ Tue Feb 23, 2010 10:36 pm ]
I've seen the drill out & rev, it look's wrong!!!
Yes it give's you more room, but every time you get into the car you look at it, it stopped me buying it bout 3 yr ago. 8O
Author:  sr20zook [ Wed Feb 24, 2010 1:09 am ]
thats how to do it, cut up a tin top rear window and use the 2 halves
Author:  joeblow [ Wed Feb 24, 2010 1:49 am ]
mine also started life as a cab-chassis. cut the centre out leaving the gutter, then place as much of the rear of a hard top as you like. you would be surprised at how well it lines up.
Author:  charlie_brown [ Wed Feb 24, 2010 1:51 am ]
while I'm was keen on seeing how moving the back wall works I actually moved away from that idea. Now I'm planning to chop around 600mm from around the rear wheel well of a SWB soft top and joining it back together again.
I also have a fibreglass hardtop which I'll do the same thing to.
This is on a lwb so it won't look too rediculous (I hope)
Here are some amateur pics of the proposed mods:
Author:  joeblow [ Wed Feb 24, 2010 1:57 am ]
same thing was done to this....
Author:  squirezook [ Wed Feb 24, 2010 2:40 am ]
Thanks for the pic's and ideas I have some more research to do.
I like the look of the red one. Very tidy.
And yes I think the reverse would look odd! If I could of got hold of a fibreglass back I would of put that on and then built up the bottom section.
they are a bit hard to find and lots of $$
Thanks again
Author:  squirezook [ Wed Feb 24, 2010 2:50 am ]
just wondered if I use the top and sides of a tintop will my original rear fit back in?? not so keen on the rear barn door look
Author:  MrRocky [ Wed Feb 24, 2010 3:13 am ]
then weld it in
