It is currently Thu Oct 22, 2026 4:41 pm
Post new topic Reply to topic  [ 30 posts ]
Post Posted: Tue Mar 02, 2010 3:41 am
Anyone got any updates on kits available or anything for twin transfer sticks? Havent heard anything in a while. I think im gonna need em with twin lockers.
Post Posted: Tue Mar 02, 2010 3:58 am
yeah just buy an evil twin setup from here
Post Posted: Tue Mar 02, 2010 12:37 pm
I remember there was a mod you can do by cutting down two transfer sticks, anyone remember?
Post Posted: Tue Mar 02, 2010 2:45 pm
I have just done that to my car cause I'm too tight to pay for the lockdup one. Took a few hrs to get right but it's going good now
Vehicle: 1987 sierra tray back buggy
Post Posted: Tue Mar 02, 2010 3:07 pm
sweet how do you do it?
Post Posted: Tue Mar 02, 2010 3:14 pm
Post Posted: Tue Mar 02, 2010 3:52 pm
That looks so simple at first look. But then I went and had a look at a one in my back yard and started thinking. how do you get both shafts through the lock collar without splitting it? or is there an unseen split on the back side of this picture that has been welded back together? Has anyone actualy dont this them selfs? Not just a picture off the net. Want33 did you do this?
Post Posted: Tue Mar 02, 2010 3:54 pm
you could possibly take the thicker top piece off of the sticks and put them through top first?? i think its only rubber mounted.
Post Posted: Tue Mar 02, 2010 8:57 pm
The one I made is exactly the same down the bottom. Only difference is with mine is I made custom levers. So basically I did all the grinding with the transfer out of the car to get it all on than I put transfer back in and bent up sticks. Pulled levers out again and welded everthing up good. Sound easy??
Post Posted: Tue Mar 02, 2010 9:05 pm
That pic is from Zuwharrie but I did mine the same.. Still haven't fitted them yet though.. :roll:
Getting both the sticks through the collar is easy.. The trick is getting both the sticks through the spring.. It takes a fair bit of jiggling..
Because one stick ends up facing backwards it is easier to cut it off the ball part and make a new one unless you have oxy gear and can heat bend it to desired shape. The original stick will need reshaping a bit too, to move it sideways to allow room for 2nd stick.
I'll put a roll pin through mine before fitting so each stick can only move forwards or backwards... NO sideways movement at all.
Post Posted: Tue Mar 02, 2010 10:55 pm
ooo i like this. cheap, the best price for sierra owners
Post Posted: Tue Mar 02, 2010 10:59 pm
OR when you have the case apart to remove the detent ball to make this mod possible you can modify the shift rods, which gives you a different shift pattern but enables you to select 2 low, 2high, 4 low, 4 high and neutral.
you would then be able to use the standard SINGLE unmodified lever.
Post Posted: Wed Mar 03, 2010 12:13 am
That is the setup I currently have and it's a right pain in the ass.... Two sticks will be much better.
Post Posted: Wed Mar 03, 2010 1:24 am
How often do you actually use 2L jas?
Post Posted: Wed Mar 03, 2010 1:43 am
You've seen him drive.....i'm going to go with never :twisted:
Post Posted: Wed Mar 03, 2010 2:12 am
and whats the benefit on 2L
My Rig --> Click WWW
Vehicle: Nissan
Post Posted: Wed Mar 03, 2010 2:13 am
x2 :?
Pearce-toff Racing
Post Posted: Wed Mar 03, 2010 2:15 am
:rofl: :rofl: You got it.... I thought it would be an awesome mod but have only used it twice and that was only to prove I had it, never been needed on the tracks...
A rear disconnect to enable front digs, while being a lot dearer and not really a DIY mod would be SO MUCH MORE beneficial.
Post Posted: Wed Mar 03, 2010 2:17 am
Wank factor.... or if your shep you may have a reason for it :)
Vehicle: LJ50V, SJ70
Post Posted: Wed Mar 03, 2010 1:38 pm
IF you don't have power steering, and IF you have a front locker, it can save a workout on your arms, stress in the T/case and wear and tear on the front end when doing 3 point turns in 4wd, or tight twisting sections of track. Besides that, well....... :cry:
Post Posted: Thu Mar 04, 2010 11:19 pm
all u would most likely use it for is to get the little 1.3L to do burn outs in 2WL
Post Posted: Fri Mar 05, 2010 2:23 am
thats prob the best reason.
i dont use it as much now i have an air locked front but still use it.
its good to use rear drive to slide the rear adound into a better spot.
im just starting to play with my rear disconnect and that is more wank factor but has proven to be handy. i need to sort some cutting brakes but that doesnt work to well with welded rear :roll:
all fun and games
Post Posted: Fri Mar 05, 2010 12:45 pm
I have a welded front ill be looking for twin sticks and power steering soon :(
Post Posted: Fri Mar 05, 2010 8:30 pm
rear disconects i know what they do and i have seen them used but i can't think of any senario that it would help. Can some one that has one tell me what they have used them for
Post Posted: Fri Mar 05, 2010 9:05 pm
front burns. think about doing a burn out in a fwd car with the hand brake on, very tight turning circle
Post Posted: Fri Mar 05, 2010 11:17 pm
Used alot in comps where you are restricted by track markers and you cant go out of bounds. Its a bit like a poor mans rear steer :wink:
Vehicle: Nissan
Post Posted: Fri Mar 05, 2010 11:19 pm
in comps when you got to turn and you need to reverse and turn again you just put ya front locca in and rear discconect in and turn no need for reverse peniltys 8)
Pearce-toff Racing
Post Posted: Sat May 15, 2010 12:59 am
New setup for gaining 2Lo
http://www.pirate4x4.com/forum/showthread.php?t=887410
Post Posted: Sat May 15, 2010 8:54 am
Oooo I want that TT shift setup.
I've played with the evil twin and I have the centre detent ball out of my rails in readiness for a twin stick, but I now suffer from occasional popping out of gear on road.
The TT setup eliminates that possibility.
Vehicle: MY2019 Jimny
Post Posted: Sat May 15, 2010 9:14 am
It allows you to properly carry a second stubby holder in your car.
I have evil twins, but honestly have never needed 2L so far...
Users browsing this forum: AdsBot [Google] and 105 guests
