| Strange Steering Problem http://auszookers.com/forum/viewtopic.php?f=5&t=10348 |
| Author: | BlueSuzy [ Wed Mar 10, 2010 4:14 pm ] |
| Post subject: | Strange Steering Problem |
Suzuki Sierra. Standard suzuki diffs. Vitara powersteering box and vitara pump. No Damper. Clean Fluid. A week ago went to the Wattagans, i hit some mud and rock,(roperd) Fairly deep for a suzuki, and since a day after it was sort of locking the steering..The mud was watery and bit of slop on the bottom. The problem is when i drive i slightly turn left, it used to return to centre by itself if i let the wheel go, Now it wants to drive in the direction i have turned it, by itself. Steering also feels heavy. Would i be correct that my kingpins will be causing this? full of mud? Or could it be a PowerSteeringbox/pump issue? (I need her for sunday!!! ARGH!) I've never had this problem before. |
| Author: | royce [ Wed Mar 10, 2010 4:17 pm ] |
| Post subject: | Re: Strange Steering Problem |
if you turn into a side street and let go of the wheel does it return then? |
| Author: | BlueSuzy [ Wed Mar 10, 2010 4:20 pm ] |
This is doing 5km/h - No ruts on road. |
| Author: | BlueSuzy [ Wed Mar 10, 2010 4:23 pm ] |
Shit.. I did tighten the box up so it had little play... Going to loosen it up now and check. |
| Author: | BlueSuzy [ Wed Mar 10, 2010 4:37 pm ] |
F'ing Der fred. It has loosened up to normal. Now. Yet to test at speed. Because i also had this weird delay in the steering..Heavy steering also. The shackles give me say eg. 1sec delay. then this other delay made it eg.2sec delay Have also replaced the main steering arm from the drop arm to the diff(forgot name) Hopefully this fixes it as one of the tierods was flogged out.. |
| Author: | shep [ Wed Mar 10, 2010 5:34 pm ] |
a boat but there is no delay. |
| Author: | BlueSuzy [ Wed Mar 10, 2010 5:50 pm ] |
But it did have a delay! Hopefully from the worn tierod/arm. Yet to test on way to work..in 1 hr. |
| Author: | Brett [ Wed Mar 10, 2010 6:28 pm ] |
wheel alinement (spelling) |
| Author: | appsie [ Wed Mar 10, 2010 8:52 pm ] |
mine used to also have this delay you speak of |
| Author: | Choppy [ Wed Mar 10, 2010 10:18 pm ] |
BlueSuzy wrote: Suzuki Sierra.
Standard suzuki diffs. Vitara powersteering box and vitara pump. No Damper. Clean Fluid. A week ago went to the Wattagans, i hit some mud and rock,(roperd) Fairly deep for a suzuki, and since a day after it was sort of locking the steering..The mud was watery and bit of slop on the bottom. The problem is when i drive i slightly turn left, it used to return to centre by itself if i let the wheel go, Now it wants to drive in the direction i have turned it, by itself. Steering also feels heavy. Would i be correct that my kingpins will be causing this? full of mud? Or could it be a PowerSteeringbox/pump issue? (I need her for sunday!!! ARGH!) I've never had this problem before. i had the same issue, wouldnt correct its self and couldnt do a u turn in a t-section the steering was sooo heavy edit: just realised you fixed your issue, but if it ever happens again check the whole lot !! |
| Author: | steak_knife [ Wed Mar 10, 2010 11:48 pm ] |
Brett wrote: wheel alinement (spelling)
That won't help. |
| Author: | BlueSuzy [ Thu Mar 11, 2010 12:54 am ] |
Stil feels tight on road. Going to loosen the box more. I shouldnt of touched it. The play/delay has gone! But stil heavyish steering. If doesnt work 2nite on way home, hubs are being stripped.. |
| Author: | BlueSuzy [ Thu Mar 11, 2010 5:04 pm ] |
Jacked up the car, turned the 2 hubs together without the draglink to the box. Turns like magic. I then lowered the car onto 2 bits of laminated wood with silicone spray between. 2 for each wheel. Wheels turn easily.. 1 thing i have noticed, with the vit ps box, when i got it, i was able to push the drop arm by hand. It is now tight..With the loosening/adjusting screw loose. I think the box if fooked. Any other ideas? The unijoints in the steering column/arm are not seized either. (i have 2) i have hit them with wd40/crc spray. When i turn the steering wheel, i can feel resistance. (no draglink) Next option is disconnect ragjoint and test the column movement. If its easy, must be the box.. (Sorry for alot of thinking out loud) |
| Author: | steak_knife [ Thu Mar 11, 2010 9:21 pm ] |
Think away, we never listen anyway. Doesn't sound good, the fluid isn't buggered is it?? Kink in a hose?? |
| Author: | BlueSuzy [ Thu Mar 11, 2010 11:16 pm ] |
na and na. Feels like im going round in circles. |
| Author: | steak_knife [ Thu Mar 11, 2010 11:18 pm ] |
BlueSuzy wrote: na and na.
