It is currently Wed Oct 07, 2026 6:25 am
Post Posted: Thu Mar 11, 2010 12:11 am
hey guys, i have a dilema with my electrics, my battery isnt holding charge for sum reason, when i drive at night with my headlights on the radio cuts in and out , and with the headlights on there is no power to the accessories .............even after running 40 minutes to work i turn it off and try and start it up and theres no power ???? doin my head in.......
Post Posted: Thu Mar 11, 2010 12:23 am
Dodgy alternator perhaps??
Post Posted: Thu Mar 11, 2010 12:33 am
bad earth
check all your earths mate
Post Posted: Thu Mar 11, 2010 1:37 am
:? start it up put multimeter on battery read, if not 14volts or more, new alternator.
Post Posted: Thu Mar 11, 2010 1:51 am
yea i tried that was about 12.50
Post Posted: Thu Mar 11, 2010 1:55 am
checked your battery water levels, made sure your battery isn't loose in the battery tray, made sure your fan belt is tensioned properly, made sure your wipers aren't in the on position if they don't work (happened to me)...
I would say bad earth or old battery... I have the same problem... I'm just too cheap to buy a new battery, I just have to make sure I park on a hill...
[quote="zookieboi"]has anyone really been far even
Post Posted: Thu Mar 11, 2010 2:03 am
the battery is maintance free , what earths exactly should i be checking?
Post Posted: Thu Mar 11, 2010 2:06 am
X2, 12.5 volt's tells me the alt is only running on 2 phases, time for an upgrade.
Post Posted: Thu Mar 11, 2010 2:29 am
check what charge is coming out of the back of the alternator. because it may be voltage drop from there to the battery. to ckeck for voltage drop put the leads of your multimetre between the + on the battery and the main lead on the back of your alternator.. there should be a voltage readout.. do the same for -.. from the - terminal on battery to the alternator body.
check all earths that you can find make sure there is one to the engine block and also to the body/chassis.
Post Posted: Thu Mar 11, 2010 2:53 am
should i upgrade to alternator to a ford unit??? is it a hard job??
Post Posted: Thu Mar 11, 2010 3:11 pm
If u pull the batery lead of the battery dose the motor stop . if so its not an earthing problem its aalternator problem. and only takes a few minits to do.
Post Posted: Thu Mar 11, 2010 4:00 pm
I would not suggest this. Alternator senses no battery voltage and can send a massive voltage spike through everything. Just use a multi on the batt and run the engine @1000rpm. You should be getting more than 13V. Takes less than a few mins to do
Maintenance free battery hey? So is it a fully sealed non lead acid batt? I assume not. Regardless of whats written on the battery check and top up the water levels.
Dan
Post Posted: Fri Mar 12, 2010 2:03 am
Top of the batt should have 6 little plugs in the with a flathead or Phillips head type hole in each you can open them with a ten cent piece... You need to fill the battery with DISTiLLED water till just below the plugs...
Post Posted: Sat Mar 13, 2010 12:46 am
how did you go mate...
have you come up with anything yet??
Users browsing this forum: No registered users and 174 guests
