It is currently Sun Oct 04, 2026 10:31 pm
Post Posted: Thu Mar 11, 2010 6:31 pm
I live in darwin and am considering buying difflockers for the frount and back. would any one be able to give me a rough price on a set?
Post Posted: Thu Mar 11, 2010 6:35 pm
www.lowrangeoffroad.com
Post Posted: Thu Mar 11, 2010 8:22 pm
yours is a maruti isn't it? you can fit 1.3 airlockers to it, best (although most expensive) optioin
Vehicle: '96 LWB trayback
Post Posted: Thu Mar 11, 2010 11:49 pm
You'll fit just about any 1.3 compatible locker to a maruti if you use 26 spline sidegears in the front.
I've got a minispool in the rear of mine and lockright in the front. Nothing all that special about the stockman diffs that makes lockers hard to source.
Post Posted: Fri Mar 12, 2010 1:20 am
just dont blow up those 4.1 diffs though
Vehicle: LJ50V, SJ70
Post Posted: Fri Mar 12, 2010 4:33 am
Isn't it only the WT Maruti's that have 1.3 size diffs? The NT Maruti's still ran 1.0 size stuff (in fact, they were called a Type 5 SJ410). Only locker available would be a Lock-right.
Post Posted: Fri Mar 12, 2010 6:21 am
Correct. Although they were all referred to as "stockman" by suzuki.
Best the OP clarify which year/model he has.
Post Posted: Fri Mar 12, 2010 2:18 pm
yes it a 92 model
Post Posted: Fri Mar 12, 2010 3:59 pm
So you have a massive range of lockers to choose from, as your diff is a standard suzuki centre, with 45/11 ratio (4.09).
And no stress if that centre dies, the ratio is NOT rare, as it is shared with the automatic jimny.
I run a maruti front and a jimny rear centre after I killed my maruti diff. It's a bolt in swap.
Post Posted: Fri Mar 12, 2010 6:14 pm
thats good to know.
Post Posted: Fri Jan 07, 2011 5:54 am
Grave dig!
Just been searching some threads about NT maruti 4.1 diffs
It seems from what I read you CAN NOT put wt centers into them, they are prue 1L stuff, not even the Ring and pinon from 4.1 NT will transfer over to a WT centre and go into a WT diff housing.
So as per normal WT is WT, NT is NT and nothing transfers!
Post Posted: Fri Jan 07, 2011 6:37 am
correct! the best you can do is, autolockers which can still e sourced from the states
or find jimny front 4.1 diffs and run jimny diffcentres with air lockers
Users browsing this forum: No registered users and 195 guests
