| diff lockers for a stockman http://auszookers.com/forum/viewtopic.php?f=5&t=10370 |
| Author: | dam_bush_boy [ Thu Mar 11, 2010 6:31 pm ] |
| Post subject: | diff lockers for a stockman |
I live in darwin and am considering buying difflockers for the frount and back. would any one be able to give me a rough price on a set? |
| Author: | tanshi [ Thu Mar 11, 2010 6:35 pm ] |
| Post subject: | Re: diff lockers for a stockman |
www.lowrangeoffroad.com |
| Author: | mrw82 [ Thu Mar 11, 2010 8:22 pm ] |
yours is a maruti isn't it? you can fit 1.3 airlockers to it, best (although most expensive) optioin |
| Author: | mnemonix [ Thu Mar 11, 2010 11:49 pm ] |
You'll fit just about any 1.3 compatible locker to a maruti if you use 26 spline sidegears in the front. I've got a minispool in the rear of mine and lockright in the front. Nothing all that special about the stockman diffs that makes lockers hard to source. |
| Author: | MrRocky [ Fri Mar 12, 2010 1:20 am ] |
just dont blow up those 4.1 diffs though |
| Author: | 303zuke [ Fri Mar 12, 2010 4:33 am ] |
Isn't it only the WT Maruti's that have 1.3 size diffs? The NT Maruti's still ran 1.0 size stuff (in fact, they were called a Type 5 SJ410). Only locker available would be a Lock-right. |
| Author: | mnemonix [ Fri Mar 12, 2010 6:21 am ] |
303zuke wrote: Isn't it only the WT Maruti's that have 1.3 size diffs? The NT Maruti's still ran 1.0 size stuff (in fact, they were called a Type 5 SJ410).
Correct. Although they were all referred to as "stockman" by suzuki. Best the OP clarify which year/model he has. |
| Author: | dam_bush_boy [ Fri Mar 12, 2010 2:18 pm ] |
yes it a 92 model |
| Author: | mnemonix [ Fri Mar 12, 2010 3:59 pm ] |
So you have a massive range of lockers to choose from, as your diff is a standard suzuki centre, with 45/11 ratio (4.09). And no stress if that centre dies, the ratio is NOT rare, as it is shared with the automatic jimny. I run a maruti front and a jimny rear centre after I killed my maruti diff. It's a bolt in swap. |
| Author: | dam_bush_boy [ Fri Mar 12, 2010 6:14 pm ] |
thats good to know. |
| Author: | remydog05 [ Fri Jan 07, 2011 5:54 am ] |
Grave dig! Just been searching some threads about NT maruti 4.1 diffs It seems from what I read you CAN NOT put wt centers into them, they are prue 1L stuff, not even the Ring and pinon from 4.1 NT will transfer over to a WT centre and go into a WT diff housing. So as per normal WT is WT, NT is NT and nothing transfers! |
| Author: | tanshi [ Fri Jan 07, 2011 6:37 am ] |
correct! the best you can do is, autolockers which can still e sourced from the states or find jimny front 4.1 diffs and run jimny diffcentres with air lockers |
