It is currently Sat Nov 14, 2026 7:55 am
Post Posted: Tue Jun 05, 2007 6:10 am
I have an LJ80 which requires a new engine. I have a Maruti bottom end . and would have been quite happy with that until I read about a 1.0 out to a 1.2 on another Suzuki forum. the guy only posted once in 06 and the reference to his engine was in his avatar. and he went by the name of erosion king
So I was wondering if anyone has enlarged a F10 and what pistons you used? What were the results and was it worth it?
The car was my grandfathers and I am not interested in a non standard engine conversion.
Vehicle: LJ20 LJ50
Post Posted: Tue Jun 05, 2007 9:42 pm
if you want more herbs you can just up the compression and run a better camshaft, good exhaust and bigger carby.
Then it is still standard engine and won't have paper thin walls in teh engine. If you bore out a 1 litre that far then the engine WILL NOT last very long. Unles you over bore it and then put some sleeves in. $$$$$$$$$$$$$$$$
first option much cheaper in the long run
They used the 1 litre in a sc100 sports car. They are popular overseas. Many options for these engines are twin mikunis or dellertos or a quad cab setup of a 1100cc motor bike.
Fuel injection can be added by using either a single point continous spray version (TBI from a late model sierra engine) or some aftermarket multi point injection
Use a 1.3 dizzy ( with the electronic ignition ( slips straight in) More info on that at LJ10.com
So use google and search for SC100, LJ80 mods and the world is your oyster. Heaps to find.
Camels have nice toes
Users browsing this forum: Google Adsense [Bot] and 75 guests
