| knocking nosie http://auszookers.com/forum/viewtopic.php?f=5&t=10434 |
| Author: | jakeyr [ Mon Mar 15, 2010 4:57 am ] |
| Post subject: | knocking nosie |
im after some advice when im in 4wd there is a nosie (knocking) which sounds like it is coming from the LHF of the car when im accelerating there is no nosie but if im slowing down or rolling thats when it starts it will even cause the tc to shake. what do ya 's think |
| Author: | want33s [ Mon Mar 15, 2010 12:53 pm ] |
| Post subject: | Re: knocking nosie |
Check the uni joints in the front shaft. |
| Author: | jakeyr [ Tue Mar 16, 2010 2:08 am ] |
yea there all ok |
| Author: | atari4x4 [ Tue Mar 16, 2010 2:13 am ] |
have a mate shake it & check over the front end looking for the noise, it could be loose shackles, rooted shackle bushes, loose u-bolts... or someone suck in your engine bay & they're trying to get out? |
| Author: | jakeyr [ Tue Mar 16, 2010 2:35 am ] |
i dont think it is the shackles cos the tc starts to shake too im thinking could it be the diff or the axles, would they make a knocking nosie ? |
| Author: | Red89 [ Tue Mar 16, 2010 2:45 am ] |
TC bushes or arms bent or busted resulting in the stick hitting on the body ? |
| Author: | jakeyr [ Tue Mar 16, 2010 2:50 am ] |
i forgot to mention that i have changed the tc and it still happend |
| Author: | jonno_racing [ Tue Mar 16, 2010 4:30 am ] |
i had that and it was the leaver hiting the body... could be nearly anything though broken gearbox mount and box hitting firewall? |
| Author: | Ben_Sierra [ Tue Mar 16, 2010 4:48 am ] |
If it was a gearbox mount you'd expect it in 2WD as well... It's gotta be somewhere in the front drivetrain. |
| Author: | jonno_racing [ Tue Mar 16, 2010 12:14 pm ] |
no, there is much more load on the drivetrain in 4wd. |
| Author: | shep [ Tue Mar 16, 2010 12:18 pm ] |
bet ya it is a fucked slip joint in the front tailshaft. |
| Author: | steak_knife [ Tue Mar 16, 2010 1:49 pm ] |
shep wrote: bet ya it is a fucked slip joint in the front tailshaft.
Was thinking that, or the front diff's about to go BUNG!!!! |
| Author: | jakeyr [ Tue Apr 06, 2010 6:14 pm ] |
whats the slip joint ? is that where the front shaft slides together? could it be the cv |
| Author: | jakeyr [ Thu Apr 08, 2010 12:22 am ] |
| Author: | alex [ Thu Apr 08, 2010 12:26 am ] |
jakeyr wrote: whats the slip joint ? is that where the front shaft slides together?
yes |
| Author: | eldo [ Thu Apr 08, 2010 2:13 am ] |
wtf is a nosie? |
| Author: | jakeyr [ Thu Apr 08, 2010 3:04 am ] |
Noise |
| Author: | jakeyr [ Fri May 14, 2010 3:17 pm ] |
how can you tell when the slip joint is gone? |
| Author: | steak_knife [ Fri May 14, 2010 9:28 pm ] |
jakeyr wrote: how can you tell when the slip joint is gone?
Same as a uni, grab it & give it a good shake, twist & pivot.. if it has noise or play while doing above said, it's probably buggered, Try greasing it, if the noise/vibration goes away your in the right spot. Should be greased on a monthly bases anyway, more if you only play in mud & water.. |
