It is currently Fri Oct 09, 2026 11:22 pm
Post Posted: Mon Mar 15, 2010 7:14 pm
hi i was wondering weather the rear pinion nut on my 91 wt has normal or reverse thread asit seems really hard to remove compaired to the front ones
Post Posted: Mon Mar 15, 2010 7:16 pm
righty tighty... lefty loosey...
I usually bolt a length of steel to the flange and then use a breaker bar and socket with a long piece of pipe.
Post Posted: Mon Mar 15, 2010 7:19 pm
There are 2 flats machined into the output shaft, and the nut is dented in those locations. That can make it hard to get off.
rattle gun and some heat
navara on 33s. hopfully rear air locker soon
Post Posted: Mon Mar 15, 2010 7:26 pm
think i might try the welder idea as i do not have an oxy cheers for your input guys now to get it open an put my crawlers in.
Post Posted: Mon Mar 15, 2010 7:44 pm
I took mine to the local mechanic and he got em off with a rattle gun in 5 seconds flat...
I want my old sig back :(
Post Posted: Mon Mar 15, 2010 8:07 pm
i work on computers all day i use that one a fair bit when i get around to spinning spanners... :oops:
Post Posted: Mon Mar 15, 2010 8:16 pm
I try to teach apprentices that rule to, thay still snap thing tho.. :roll:
Users browsing this forum: Google [Bot] and 175 guests
