http://auszookers.com/forum/
rear pinion flange nut on transfer
http://auszookers.com/forum/viewtopic.php?f=5&t=10442
Author:  bj1910 [ Mon Mar 15, 2010 7:14 pm ]
Post subject:  rear pinion flange nut on transfer
hi i was wondering weather the rear pinion nut on my 91 wt has normal or reverse thread asit seems really hard to remove compaired to the front ones
Author:  want33s [ Mon Mar 15, 2010 7:16 pm ]
Post subject:  Re: rear pinion flange nut on transfer
righty tighty... lefty loosey...
I usually bolt a length of steel to the flange and then use a breaker bar and socket with a long piece of pipe.
Author:  Damo [ Mon Mar 15, 2010 7:19 pm ]
There are 2 flats machined into the output shaft, and the nut is dented in those locations. That can make it hard to get off.
Author:  brendan [ Mon Mar 15, 2010 7:19 pm ]
rattle gun and some heat
Author:  bj1910 [ Mon Mar 15, 2010 7:26 pm ]
think i might try the welder idea as i do not have an oxy cheers for your input guys now to get it open an put my crawlers in.
Author:  Ben_Sierra [ Mon Mar 15, 2010 7:44 pm ]
I took mine to the local mechanic and he got em off with a rattle gun in 5 seconds flat...
Author:  atari4x4 [ Mon Mar 15, 2010 8:07 pm ]
i work on computers all day i use that one a fair bit when i get around to spinning spanners... :oops:
Author:  steak_knife [ Mon Mar 15, 2010 8:16 pm ]
I try to teach apprentices that rule to, thay still snap thing tho.. :roll:
