It is currently Sat Oct 10, 2026 4:03 am
Post Posted: Tue Mar 16, 2010 3:06 pm
i removed the cover off my 4x4 gear shifter the other day to find that when im putting the car into 4x4 my front drive shaft instantly stats spinning. when trying to change back from 4x4 low or into low from high it grinds, but if you press the clutch in the drive shaft disengages and you can change the gear. this isnt right does any one know what this problem would be and how can i fix it?
cheers luke
Post Posted: Tue Mar 16, 2010 3:10 pm
locks your hubs before you shift
put the clutch in
fixed :)
Your problem, clutch is meant to be on the floor during change. :roll:
Post Posted: Tue Mar 16, 2010 3:13 pm
oh ok well with my coily i never had to press the clutch in :S it all makes sense now i feel like a dooch dont i :P can any one help on my other question
Post Posted: Tue Mar 16, 2010 3:29 pm
if your hubs are locked and you are moving in a straight line you can move from 2h to 4h with no clutch usually and some could go 4l to 4h but its better to use the clutch as you are engaging gears like a gearbox
Post Posted: Tue Mar 16, 2010 3:37 pm
ok cool thanks this whole new leafy lwb set up is so different to my coily. and atm starting to think it was a bad idea haha
Post Posted: Tue Mar 16, 2010 3:48 pm
stop moving and put the clutch in from high to low or back.
2H to 4H can be done anytime
Post Posted: Tue Mar 16, 2010 4:52 pm
the thing in my glove box says
2H to 4H can be done while moving as long as wheels are straight, I usually put clutch in aswell to make it easier on the transfer (prob not neccisary)
4H to 4L, should only be done when car is stationary
dont engage 4H or 4L if hubs arent locked in,
and dont engage 4H or 4L one tarmac or hard grippy surfaces when there is no slip allowed (winds the transfer up or something)
or something along those lines
My Rig --> Click WWW
Users browsing this forum: No registered users and 207 guests
