Joined: Sun Jun 17, 2007 11:30 pm Posts: 65 Location: Sydney
Posted: Tue Jun 19, 2007 4:33 pm
I have a 84 Sierra and the leaf suspension is flat when the car is unloaded, so as you can see, i need some new springs, i was wanting to put 31's on the car, but i am worryed that with these new springs plus the nessarry 2' body lift, the drive shafts, trans/gear levers, and brake lins may not be long enough.
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
Posted: Tue Jun 19, 2007 6:02 pm
you shouldn't have any issues with the suspension lift affecting any drivetrain stuff. under full flex you might find the front brake lines stretched to the limit. All shafts are long enough for a 2inch spring lift.
you might need a thicker steering biscuit when you do a body lift, and may need to take a look at making sure you can still get the 4wd lever in to gear and it doesn't hit the body.
Users browsing this forum: No registered users and 75 guests
