It is currently Mon Oct 19, 2026 8:17 pm
Post Posted: Fri May 14, 2010 10:01 am
been thinking about getting this 95 lwb vitara with a 2.5v6. will it run ok if the computer hasnt been swapped?
Go Hard, Trailer Home
Post Posted: Fri May 14, 2010 10:06 am
if you swap the intake, the IAC is different from memory.
& I think a couple of others, at least the plug's are..
Post Posted: Fri May 14, 2010 11:23 pm
What about if you just run with the 2.5 V6 short motor and use the heads, manifold and wiring off the 2.0 V6? Would that work?
Users browsing this forum: Google [Bot] and 229 guests
