Joined: Sun Aug 27, 2006 11:30 pm Posts: 818 Location: Sydney
Posted: Sun Jun 24, 2007 4:39 am
Are Redline gear oils worth their money?
I have noisy rear diff, which was installed when I went to the airlocker. The diff is noisy but has been OK'd by the driveline specialist so it shouldn't crap it self anytime soon.
Redline "claim" it can reduce a noisy diff.
Has anyone tried it and is it worth it?
I can put up with the noise, which occurs between 50-60 and 100-110km/h, and my only other option is to change the ring/pinion.
what kind of noise is it? if its a vibration it could be your unis or your tailshaft out of phase. (doesnt line up).
mine was unis and out of phase and i only had the issue at certain revs also.
with oil additives they are normally rather thick so i would personally only use what is recommended by the locker manufacturer.. lest you void your warranty if it does blow up..
Users browsing this forum: Google [Bot] and 254 guests
