| Brake probs http://auszookers.com/forum/viewtopic.php?f=5&t=1121 |
| Author: | sosilboy [ Mon Jun 25, 2007 11:19 pm ] |
| Post subject: | Brake probs |
First thing as soon as i start rolling, my zook feels like the brakes are on and nearly stalls when i take off. i need to take off in 4L sometimes just to get moving. it eventually wears away though????? help me |
| Author: | Bruce [ Mon Jun 25, 2007 11:22 pm ] |
| Post subject: | Re: Brake probs |
Maybe a sticking brake cyl ? Have you looked at them? |
| Author: | TZAR [ Mon Jun 25, 2007 11:41 pm ] |
handbrake cable may be seizing Wheel cylinders may be siezed Brakes may be over adjusted Master cylinder may be seized Transfer case bearings may be seized Gearbox bearings may be seized Wheel bearing may be over adjusted Wheel bearings may be seized Tyres could be flat Diff bearings may be seized Pinion bearings may be seized two different size tyres on front and rear |
| Author: | steve [ Tue Jun 26, 2007 1:13 am ] |
sosi, have you got the front hubs unlocked ? if you have the front hubs locked you may be experiencing "wind up". Dont; drive around in 4wd on the streets. apart from that go through TZARs check list. You could have some seized brake cylinders. |
| Author: | TZAR [ Tue Jun 26, 2007 8:36 pm ] |
If it is a very early 1 litre you can't unlock the hubs. Also has drum brakes on the front and has 4 wheel cylinders at $40 each. Throw the whole lot away and get nt parts and slide them in. Bigger cv's disc brakes locking hubs for less than you can get the front brakes done. |
