It is currently Tue Aug 04, 2026 6:14 am
Post Posted: Wed Apr 21, 2010 3:03 am
Will a wt centre fit into a coily front diff housing??
Post Posted: Wed Apr 21, 2010 3:04 am
Im pretty sure no...
Nothing fits a coily :thefinger: :thefinger:
TWIN LOCK IT & JUST DRIVE!
Post Posted: Wed Apr 21, 2010 3:19 am
i read something about it the other day but i didnt take much notice because it was about a coily bahahah sorry mate maybe look in the tech section
Post Posted: Wed Apr 21, 2010 10:28 am
No.....coily front is the reverse pinion type. Not sure of it's technical terminology, either way, no.
Post Posted: Wed Apr 21, 2010 1:27 pm
YES It will fit.
You will have to move the steering arms. (unsure what you can use to change the hub arms, More reasearch needed)
Coily is Hipinion so arms run under diff centre.
WT is low pinion.
Post Posted: Wed Apr 21, 2010 1:32 pm
YES It will fit.
WT is low pinion.
To clarify BlueSuzy's point, the tie rod on a coily runs behind the diff. The diff centre is a high pinion type and the tie rod runs underneath that. If you were to fit a WT diff centre you would not be able to fit the tie rod back on.
Post Posted: Wed Apr 21, 2010 1:36 pm
Damo wrote:
YES It will fit.
WT is low pinion.
Thanks :oops:
(Its too early, i just woke up) :oops:
At least i got the YES right unlike the rest of the nOoBs :finger:
Post Posted: Wed Apr 21, 2010 1:40 pm
will WT swivel hubs fit?
use the tie rod draglink and stuff from a WT
Post Posted: Wed Apr 21, 2010 2:04 pm
Use the tie rod draglink and stuff from a WT
Have heard the coily's wheel track is wider. so draglink and stuff will have to use custom or coily.
Arms unsure. (i thinkk there was talk about this not long ago, or i think it was for a jimny mainly.) :?
Post Posted: Wed Apr 21, 2010 3:36 pm
instead of going to all this trouble, why not just dump the coily and buy a WT... :D :rofl: :finger:
I want my old sig back :(
Post Posted: Wed Apr 21, 2010 7:58 pm
So it fits but it's too much dicking about to make it work. What's the point! If you want it for lokka reasons modify a jimny air lokka. Problem solvered!!
Post Posted: Wed Apr 21, 2010 8:36 pm
if you could do it with bolt on bits it would be very little dicking around.
Post Posted: Wed Apr 21, 2010 9:47 pm
WT swivel hubs fit coily, Jimny front diff center fits coily front (allowing
coilys to run 4.1 diff ratios :twisted:) and yes a WT diff center will fit in the
front if you change the swivel hub, but I'm not sure if WT axles and Coily
axles have the same spline.
Post Posted: Wed Apr 21, 2010 11:31 pm
Have you put the baby 1L size jimny front into the 1.3 size front housing?!
Jimny is 4.09 ratio.
Post Posted: Thu Apr 22, 2010 1:38 am
Well ok then something fits a coily :D
Post Posted: Thu Apr 22, 2010 2:22 am
I have a WT not a coily. I'm just beginning to nut out a coil conversion and Ive been told the coilys run a better wheel bearing setup. And maybe some steering advantages???
Post Posted: Thu Apr 22, 2010 2:36 am
Running a coily front end is ALL disadvantages. Search all the problems coilys have.
Post Posted: Thu Apr 22, 2010 2:39 am
no they don't, if anything its a little worse for larger wheels. they are the same as a vitara. and steeing is no better, just more of a pain if you want to run different ratios.
Post Posted: Thu Apr 22, 2010 2:42 am
Ok cool thanks for clearing it up
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun May 13, 2012 1:38 am
awsome thread iv got a nt and the hole point of these beast is budget budget and hagling for parts so what we have or find ,its funny u find mod cut swap all effort low cost is the way.
but anyway i just striped a coily so i have coily diffs if i can make wt centres fit i m goinng to truss these diffs and and weld all the perchers and crap on so ok all crap aside the diffs centre will defently bolt in
Green? greeeen is nice !
Post Posted: Sun May 13, 2012 9:32 am
84 NT.... 1.0 or 1.3?
Post Posted: Sun May 13, 2012 10:54 am
You will need a custom drag link and tie rod. WT ones are not long enough.
Users browsing this forum: No registered users and 268 guests
