It is currently Sat Nov 14, 2026 1:48 pm
Post Posted: Thu Apr 22, 2010 1:43 am
Need to rebuild carby on my 1 litre, am I best off rebuilding or getting a second hand one?? Do the carbys off a 1.3 fit onto the 1 litre.
I know you can get webber carbys etc. but dollars are very tight.
Post Posted: Thu Apr 22, 2010 2:33 am
they are easy to do....
don't go a weber (one 'b').....they are the taliban of the carby world....
Post Posted: Thu Apr 22, 2010 2:50 am
If I were to go after market carby what would be the way to go for the side draft 1 litre.????
Post Posted: Thu Apr 22, 2010 3:33 am
just rebuild it, kits can be had off ebay and they are easy as to do.
the 1 litre sidedraft carby works well and is reliable. the only time i've had trouble with mine is when dirty fuel goes through it, which you'd have problems no matter what carby your running.
Vehicle: LJ50V, SJ70
Post Posted: Thu Apr 22, 2010 5:02 am
The 1.3 carby is a Downdraft and it and/or it's manifold won't fit on a F10A.
As mentioned, the stock carby is fine. If you do want to go aftermarket, then a Japanese Hitachi "SU" type carb is the go. These were fitted to Datsun 1200s and 1400s from the 70's and 80's. A Datsun wrecker should be able to find one. You will need to modify the manifold or make an adapter as the mounting bolt pattern is different to the Suzuki carb.
Post Posted: Fri Apr 23, 2010 12:01 pm
Thanks guys, have got a rebuild kit for the carby. Have never had an issue with it til now, so will give it a rebirth and see how she goes.
Cheers.
Users browsing this forum: Google Adsense [Bot] and 59 guests
