| Standard steering wheel size. http://auszookers.com/forum/viewtopic.php?f=5&t=11351 |
| Author: | lauby [ Thu Apr 22, 2010 5:53 pm ] |
| Post subject: | Standard steering wheel size. |
Sierra steering wheel question. The one on mine is aftermarket, I’ve looked up the regs and found that: The diameter of any replacement wheel may be up to 25mm smaller than the original wheel but must not be less than 350mm. So i can check mine, what is the standard steering wheel size on a sierra More blurb from the rule book; Altering a steering wheel might affect a vehicle's compliance with the Australian Design Rules (ADRs) applicable to occupant impact protection. Steering wheels fitted to vehicles manufactured to comply with ADR 10/.. may only be replaced by a steering wheel which has been tested to comply with ADR10/... Couple of other ADR;s are mentioned but they appear to refer to airbags, am I correct in assuming a Sierra is built to ADR10/ ? cheers |
| Author: | BlueSuzy [ Thu Apr 22, 2010 6:01 pm ] |
| Post subject: | Re: Standard steering wheel size. |
If you have airbags(you don't) It's illegal to change the steering wheel to a non airbag type. A standard 1.3 sierra's steering wheel OD is 395mm So your allowed a 370mm wheel minimum. Many wheels are smaller than this and still pass rego/inspections. |
| Author: | lauby [ Thu Apr 22, 2010 6:08 pm ] |
BlueSuzy wrote: So your allowed a 370mm wheel minimum. hmmm, i think mines much smaller than that |
| Author: | tanshi [ Thu Apr 22, 2010 6:15 pm ] |
most after market ones that i have seen are about 350mm you can check your conmpliance places under the bonnet to see if if has adr 10 applied |
| Author: | lauby [ Thu Apr 22, 2010 9:32 pm ] |
hmm, i just went out to the car and measured mine, 325 - 330mm It's a bit of a pain actually, not because if i kept it i'd have Popeye forearms in 3 months but while driving, it conceals most of the dash info. I'm going hunting for a new ADR10/ one ( what ever that turns out to be ), suggestions / recommendations where what to buy are appreciated, cheers. |
| Author: | lauby [ Sun May 09, 2010 11:29 am ] |
i hate threads that don't seem to finish i tried ebay supercheap repco google cashconvertors
Before - 320ish mm dia
After - 355ish mm dia. Ha ha, who da boss now ? ME, it says so on my wheel The new one is not a rubber finish, like the $79 dollar jobby, i doubt it's leather but it's some kind of stuff that requires real stitching as opposed to moulded rubber stitch. Next issue to clarify will be the after market seats, then all is above board and i'm going to get a BL approved down DOT. |
| Author: | eldo [ Sun May 09, 2010 11:33 am ] |
i have one of those cheap woodgrain wheels, and im getting popeye arms |
| Author: | gypsy [ Sun May 09, 2010 11:36 am ] |
does that wheel have a flat bottom cause u cant have them if they do |
| Author: | lauby [ Sun May 09, 2010 11:42 am ] |
yeah it does. there were a few options in a ADR10/ ' D ' wheel. I liked the idea as easier to get in and out when swinging the legs. Why you say you can't have them ? |
| Author: | steak_knife [ Sun May 09, 2010 8:21 pm ] |
lauby wrote: yeah it does. there were a few options in a ADR10/ ' D ' wheel. I liked the idea as easier to get in and out when swinging the legs. Why you say you can't have them ?
X2, never thought that would be a problem. |
| Author: | shandy92 [ Mon May 10, 2010 10:58 am ] |
steknig wrote: lauby wrote: yeah it does. there were a few options in a ADR10/ ' D ' wheel. I liked the idea as easier to get in and out when swinging the legs. Why you say you can't have them ? X2, never thought that would be a problem. im not sure about this, as the a lot of the newer performance cars that i get to drive at work(car wash) have the flat bottom. but maybe its ok as it a factory option. i will say it make getting in and out very easy for me being 6 ft 2-3" Mitch |
| Author: | atari4x4 [ Mon May 10, 2010 11:14 am ] |
i find the off centre & flat bottom wheels really annoying, ended up with this on my Vitara cause it was the only one I could find that wasn't off centre & all flashy & blingy.
