It is currently Sat Nov 14, 2026 1:15 pm
Post Posted: Fri Apr 23, 2010 12:56 am
Wat are the pros and cons ??? i run 2 inch ones
2''lift 31's twin locked & 6.5s
Post Posted: Fri Apr 23, 2010 2:06 am
With normal or lifted springs they will give you just under 1" of lift. Though due to making the shackle angle more upright it will be more rigid thus giving a rougher ride. if you have a half RUF on the front they are a benifit. Depending on which ones you are using the can allow the diffs to wander a little, the welded type like Fatzooks don't suffer as much from this, although there is more leverage on the bushes you only get a little more movement then standard shackles..
Personally I won't use them to gain lift, more to get the correct shackle angle.
Post Posted: Fri Apr 23, 2010 2:08 am
Pro's:
Increased wheel travel
Cheap "Suspension lift" (1" of shackle length is half an inch higher)
Con's:
Not legal in all states
Does lower your approach angle slightly
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Fri Apr 23, 2010 2:12 am
lordfury007 wrote:
Pro's:
The only way they will aid in wheel travel is if the spring is long enough to still produce a decent shackle angle.
Post Posted: Fri Apr 23, 2010 2:17 am
oh ok cos ive got standed set up with 2 inch lifted
Post Posted: Fri Apr 23, 2010 2:34 am
lordfury007 wrote:
Pro's:
:rofl: ............bloody wives tales!...........
there are no pro's............
Post Posted: Fri Apr 23, 2010 3:57 am
joeblow wrote:
lordfury007 wrote:
Pro's:
There's always ya mum.
Mine is pro's for offroad.
but con's on road.
Users browsing this forum: No registered users and 70 guests
