It is currently Sat Nov 14, 2026 6:51 pm
Post Posted: Sat Apr 24, 2010 3:14 am
Choke comes on once engine is warm. Flushed the rad and seems to fix it tempary. Should i give it a power flush? The flutes look blocked up. Does that rad cleanng product work? Or can I cut the choke off? Im heading up the beach for a wheel and dont wanna run out of fuel. Any ideas
Post Posted: Sun Apr 25, 2010 1:41 am
Help needed. This things costing more than the 100 to run
Post Posted: Sun Apr 25, 2010 3:07 am
You could tie the choke open, would work.
Dont "power flush" your radiator, all that will do is f*#k it, get it cleaned out at a rad shop or get a new one.
Post Posted: Sun Apr 25, 2010 3:22 am
take the coolant lines off the carby. you may notice that the inlet and outlet could be blocked with corrosion. clear it out with some wire. place the inlet hose back on but not the outlet, start the engine and wait for water to come through. when it does turn it off and hook the outlet back up. all should be good then.
Users browsing this forum: No registered users and 67 guests
