It is currently Fri Oct 16, 2026 3:35 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Post Posted: Mon May 03, 2010 11:19 am
These benders any good, thinking of getting one to make up an exo and front and rear bars.
Any other suggestions?
http://cgi.ebay.com.au/NEW-16-TON-HYDRA ... 335caa5d6d
http://cgi.ebay.com.au/16-Ton-Pipe-Tube ... 27b15509c8
Post Posted: Mon May 03, 2010 11:25 am
nope....i have one......is crap. but i only use it for 20mm pipe, anything bigger and it creases bad.
thats why i will be making my own.....
Post Posted: Mon May 03, 2010 11:27 am
There is a way to fix those benders to stop them creasing the pipe you need an oxy and a mig though mine works a treat now
Post Posted: Mon May 03, 2010 11:30 am
Not really. They are for pipe. You want to use TUBE. Tube benders are considerably dearer, but they will nett a better result for the items you wish to make.
The problem with the pipe benders is die size and radius. The dies are almost always imperial, but we get alot of metric tube and pipe in australia. This means you get a poor fit between the pipe and die, and crushing/ kinking is the result. Also the rollers dint the pipe/ tube.
For the exo, you will want to use a 32NB medium black at the very least. The 1 3/4" (closest to 32NB? might be 1 1/2".....) die that comes with the bender will have a MASSIVE radius, that really doesn't suit the application.
If you are clever with your exo design, you can still get a good looking/ effective cage, but only after you solve the tube crushing/ kinking/ dinting poor fitting die problems.
My 2 cents.
Pete
Post Posted: Mon May 03, 2010 11:52 am
what did you do to it zookster?
any links to a not too expensive tube bender then?
Go hard,
Post Posted: Mon May 03, 2010 11:56 am
for front and rear bars they are fine. an exo maybe but it might come out looking a bit ugly and won't have 100% strength. for the bars it is all to do with working with what you've got.
This is my front bar that i made using on of those benders:
And my sliders:
They have their faults but both the front bar and the sliders have taken a lot of abusing and neither are looking worse for wear, except for pain :P
Post Posted: Mon May 03, 2010 11:59 am
there really isn't a not too expensive tube bender on the market. and the dies alone start to add up some dollars. I was lookin recently and I am going to make a bender to suit the dies of a US company. For a die to fit 1 size of tube (will not get proper bends with anything but the ONE designated size) you are looking at $250US + frieght. If you want aus, it is around $650-$800 for a die set (one size).
Post Posted: Mon May 03, 2010 12:02 pm
I get die sets for my speedworx bender for under $500 a set. Still dear, but it works every time.
Post Posted: Mon May 03, 2010 12:04 pm
may i ask who through?
Post Posted: Mon May 03, 2010 12:12 pm
Speedworx
Post Posted: Mon May 03, 2010 12:47 pm
I made all my bars on my zuk and countless other trucks with one of those , but mine did come with a set of imperial and metric dies , Cheers Paul.
Post Posted: Mon May 03, 2010 12:48 pm
zook fan, what sort of radius can you get for a 90 degree bend in 2"
Post Posted: Mon May 03, 2010 2:25 pm
As already said they are only good for light work and small bends. There is a Yellow and black one that lays on its side. it allows the dies to sit further apart and it bends a little better. I can't find it on the net but when you find it you will see what I mean. from memmory they are about $30 more then those.
Post Posted: Mon May 03, 2010 11:37 pm
Pipe is the same size around the world, there is no metric or imperial versions!!! its just either 32nb, 1.25" 1 1/4" 42.1mm od etc, depending on the wrong way people say it, you need to get good quality pipe not cheap Chinese shit, Australian tube mills make a nice product called oztube that bends well, likewise Orrcon make it here a well, try and ask for AS1163 or 350mpa pipe as its stronger and made for Structural applications so bends better
tube is different as its measured by its od, you can get the same grades though, its all useless if your dies are shit Chinese things though
Post Posted: Mon May 03, 2010 11:41 pm
Pipe is the same size around the world, there is no metric or imperial versions!!! its just either 32nb, 1.25" 1 1/4" 42.1mm od etc, depending on the wrong way people say it, you need to get good quality pipe not cheap Chinese shit, Australian tube mills make a nice product called oztube that bends well, likewise Orrcon make it here a well, try and ask for AS1163 or 350mps pipe as its stronger and made for Structural applications so bends better
That is the biggest problem.
When Shep did his canopy he had what we assumed to be shit chinese steel. It fit the dies quite well but just wrinkled and deformed.
I have used these types of bender before with decent tube and haven't had any problems
Post Posted: Tue May 04, 2010 5:03 am
Sounds like getting one wont be too bad, but i jsut need to buy good quality steel
Post Posted: Tue May 04, 2010 5:18 am
you will not get anywhere near a 90 degree bend with 2" no matter what steel you use. I have tried with both high and low quality steel and both got somewhere around ~70 degrees before they were kinked. not just distorted but kinked, proper fucked.
Post Posted: Tue May 04, 2010 6:02 am
looked at a fence gate lately? what do you reckon they are made from :wink:
you need good dies though
Post Posted: Tue May 04, 2010 6:28 am
and put the seam in the right place too :?
Post Posted: Tue May 04, 2010 8:59 am
wow royce is cutting me down a lot lately, i'm going to stop using direct words :D ... What fence gate is made with 2" tube royce? that would be a heavy gate.. Most of the gates around here would be like 32nb tops. from the pictures in the links he provided i doubt that they are very good dies, more than likely the same sort of ones that I have. Where would you put the seam ball? on top of the bend, on the bottom or on the side? I'm pretty sure on the side allows it to kink easily, on the bottom it kinks up and into the top wall. I don't think i have tried on the top though
Post Posted: Tue May 04, 2010 9:04 am
wtf, I havent been on here for a week, harden up princess
its not tube its pipe, please try and stop looking silly by referring to it the wrong way, actually to be accurate its Circular Hollow Section or CHS
Post Posted: Tue May 04, 2010 9:11 am
i was joking, forgot the emoticon... will fix it.
i was answering his question. he asked about 2" which is tube. you were talking about pipe or CHS and I answered you with a pipe dimension 32nb so where did i go wrong?
Post Posted: Tue May 04, 2010 9:19 am
thread is about pipe benders not tube benders :)
you can get 2" pipe, which is 50nb or 60.3mm
cant get 2" tube :)
Post Posted: Tue May 04, 2010 10:07 am
Ok, can someone clear this up for me cos I'm not sure:
What is the difference between tube and pipe?
I want my old sig back :(
Post Posted: Tue May 04, 2010 10:09 am
cant get 2" tube :)
Maybe not from the regular steel suppliers but it is available from specialist ones 8)
http://www.performancemetalsaustralia.c ... rt/PSM5021
Post Posted: Tue May 04, 2010 10:10 am
Tube is good pipe is shit :lol:
Post Posted: Tue May 04, 2010 10:13 am
pipe is cheap and tube is that stuff flash people use. :wink:
Post Posted: Tue May 04, 2010 10:15 am
pipe is the shit you use for running water lines and stuff. a lot of people use it for fabrication because it is cheap. tube is stronger and designed for motorsports (i think). For roll cages you need to be using tube, pipe does not cut it. royce can give you a good run down, he has before in other threads ;)
Post Posted: Tue May 04, 2010 10:37 am
tube is measured by its outside diameter and wall thickness in mm usually, pipe is in nominal bore and weight and all are set sizes anyway but you need to be smarter to remember them all :wink:
neither is cheaper than the other as its all based on the grade regardless, tube mills dont care what the OD is when they pump it out
if you want to get technical about grades both can be bought in AS1163 (the aus standard for structural formed sections in Australia) but usually pipe (CHS) is the size asked for over tube, exhausts on the other hand are usually made from tube :wink:, pipe can also have other grades attached to it depending on its type and end use, AS1074 for water pipe (usually medium wall CHS) API5lb for ERW (welded seam pipe) for high pressure gas and solid transmission, A106B for seamless pipes, up to Chrome Moly stuff for heat exchangers and stuff
tube is the in thing for rollcages and such as CAMS and CCDA list tube sizes in the specs, using pipe in a size suitable nets you with a larger OD and heavier wall than the bare min required, which will cost you weight, both can be bought in the correct grade needed and both can be ordered in the yield and ductability you need for the job
next lesson I might talk about real high strength carbon steel pipe used in gas wells that would make ace tube bars
One day I will tell you lot about the real big national Pipe supply company I work for :wink:
Post Posted: Tue May 04, 2010 11:46 am
aaaahhhhhhhhhhrrrrrgggggggggggg
All I want is to build an exo and some barwork, eg sliders, front and rear bars
will one of these do the job?
assuming that i use say 32nb?? i think thats one everyone is using for exo's
Users browsing this forum: No registered users and 289 guests
