| gv 2006 2inch lift http://auszookers.com/forum/viewtopic.php?f=5&t=11641 |
| Author: | jonnybravo1 [ Fri May 07, 2010 10:11 am ] |
| Post subject: | gv 2006 2inch lift |
Hi Guys could someone please recommend a cheap but effective way to lift my 06 5door g vitara ,r coil spacers a viable way, body lift or lift kit the best way to go, i only take it off road a hand full of time a year and don't want to spend a mint. |
| Author: | ODA1 [ Fri May 07, 2010 11:23 am ] |
| Post subject: | Re: gv 2006 2inch lift |
Rocky road in the us do a cheap spacer lift. You could go just coils for $400, iron man do a 35 mm lift kit for about $880 I too can supply a few bits - www.outdoorauto.com.au |
| Author: | Built4thrashing [ Fri May 07, 2010 11:55 am ] |
body lift is not possible. Iron man kit looks pretty good for the price. 30 to 45mm lift depending of drivetrain and options you have fitted. dont bother even asking ARB as they only offer a 25mm lift. thats it. and it will sag down to 20mm. not worth worrying about. B4T |
| Author: | MacDaddy [ Fri May 07, 2010 12:55 pm ] |
I found out from Steknig i think it was, who has owned a GV much longer than me, that spacers are a big NO on the GV ! I would go the Ironman 35mm Lift kit for $840, apparently the 35mm is a proper 2in lift, and thats what i am gettin for my 2001 GV ! |
| Author: | steak_knife [ Fri May 07, 2010 10:05 pm ] |
MacBear wrote: I found out from Steknig i think it was, who has owned a GV much longer than me, that spacers are a big NO on the GV !
I would go the Ironman 35mm Lift kit for $840, apparently the 35mm is a proper 2in lift, and thats what i am gettin for my 2001 GV ! 06 Mr Mcbear, diffrent car, but same oppion on spacer's. Don't go over the 40mm, If you do you rear wheel alinment will be out of adjustment & will have, 1. stupid amount's of pos camber. 2. Toe in once again to the stupid amount & the caster can't be adjusted either. Oh, just incase you don't know what that mean's, your tyre's WILL flog out, it WILL drive like a twitchy peice of shit & nothing can be done until you either get control arm's made up or remove the lift. Steve. |
