| Vitara p/s fittings http://auszookers.com/forum/viewtopic.php?f=5&t=11642 |
| Author: | zookster666 [ Fri May 07, 2010 10:48 am ] |
| Post subject: | Vitara p/s fittings |
Does anyone know where to get the banjo bolt with copper washers to suit the vitara p/s box high pressure line. Brisbane area would be good Also does anyone know what sort of rubber hose I can use for the low pressure hose from the box to the resovoir does it have to be a steel line like the stock one? Zookster |
| Author: | mrw82 [ Fri May 07, 2010 10:54 am ] |
| Post subject: | Re: Vitara p/s fittings |
go to enzed. they will have everything you need. the low pressure line can be just low pressure hose (SAE R6 or R7). but if it is a long run it would be better (and cheaper) to run a length of steel tube (called bundy tube) |
| Author: | zookster666 [ Fri May 07, 2010 11:04 am ] |
Thanks for the fast reply bud will try them tomorrow |
