It is currently Sat Nov 14, 2026 12:05 pm
Post Posted: Sat May 08, 2010 6:22 am
Just wondering how high i can lift the old lj81 in the shackles before there is trouble?1inch or 2?
Post Posted: Sat May 08, 2010 6:28 am
legaly as soon as u change the lenth ur looking for trouble
but most people just make there shackles 100mm long i think it adds like 40 or so mill to original length
but someone correct me if im wrong
cheers buzy
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Sat May 08, 2010 6:36 am
Wont be registered mate.
Post Posted: Sat May 08, 2010 6:53 am
Wharf don't waste your time with extended shackles, it is a dodgy old way of doing things, changes pinion angles, changes caster angle and makes car handle poorly. It is just wrong, my advise is don't do it.
Post Posted: Sat May 08, 2010 9:39 am
Cool,ill spend my time in other areas.I have taken the fuel tank out.Its nackered.Any ideas of what other suzuki model tanks can be sourced easier?I will be moving the tank from behind the diff,to above and infront of the diff under the tray.
Vehicle: Sierra Utey!
Post Posted: Sat May 08, 2010 9:45 am
If you're moving the tank anyway, just put whatever tank you want in there.
My ute..
Post Posted: Sat May 08, 2010 10:00 am
If i could run it on gas i would just stick a couple of 9kg BBQ bottles in there.
Post Posted: Sat May 08, 2010 10:04 am
It's been done! 8O
Post Posted: Sat May 08, 2010 10:06 am
Do the suzuki engines need any headwork to run gas or are they good to go?
Post Posted: Sat May 08, 2010 10:09 am
You need head work if your going to run BBQ bottle's. :roll:
Ally head's have valve insert's in em, all good for lpg, ulp.
Post Posted: Sat May 08, 2010 10:15 am
Whats with the rolling eyes?Have i said something you find stupid?
Post Posted: Sat May 08, 2010 10:23 am
:roll:
Ive filled of a bbq bottle, not a good idea to strap em to the car tho & DOT won't like it much either.
Post Posted: Sat May 08, 2010 10:27 am
DOT wont ever see it
Post Posted: Sat May 08, 2010 10:42 am
:P :P Go for it then!!!!!!!! :P :P
:roll:
Users browsing this forum: No registered users and 89 guests
