It is currently Sat Nov 14, 2026 1:23 pm
Vehicle: 4wd
Post Posted: Sat May 08, 2010 11:05 am
what's the pro's and con's?
I want a bit more lift. Are shackles a good option?
Watch out or you'll get sued.
Post Posted: Sat May 08, 2010 11:18 am
if you have longer springs they can be a good thing.
extended shackles stopped this happening to my car.
Vehicle: 4wd
Post Posted: Sat May 08, 2010 11:21 am
I don't have longer springs, just raised springs.
Post Posted: Sat May 08, 2010 11:23 am
I guess the search engines broken again.
http://www.auszookers.com/index.php?nam ... 84&start=0
http://www.auszookers.com/index.php?nam ... ic&t=11365
Post Posted: Sat May 08, 2010 12:09 pm
Unless you have longer springs they suck. They will make the ride harsher.
Why do you want more lift?
Member of C.O.R 4x4
Post Posted: Sat May 08, 2010 10:50 pm
pro: you will get a little lift.
con: they are illegal
con: your car will handle and steer like shit
Post Posted: Sat May 08, 2010 11:28 pm
on a stock vehicle with stock springs
cons
wrong castor angles
loose vague steering
not legal
harsh ride on stock springs
how many more would you like
pro if you would call it that
a small cheap lift
Vehicle: '92 Sierra
Post Posted: Sun May 09, 2010 2:34 am
Not to mention you will probably chew trhough spring bushes which makes the steering even more scary.
Post Posted: Sun May 09, 2010 11:14 pm
cons
wrong castor angles
not legal
a small cheap lift
More movement with the right springs. But takes time to setup.
Less front ramp angle clearance
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 73 guests
