http://auszookers.com/forum/
Pro's and con's of extended shackles??
http://auszookers.com/forum/viewtopic.php?f=5&t=11670
Author:  stockman [ Sat May 08, 2010 11:05 am ]
Post subject:  Pro's and con's of extended shackles??
what's the pro's and con's?
I want a bit more lift. Are shackles a good option?
Author:  shep [ Sat May 08, 2010 11:18 am ]
Post subject:  Re: Pro's and con's of extended shackles??
if you have longer springs they can be a good thing.
extended shackles stopped this happening to my car.
Author:  stockman [ Sat May 08, 2010 11:21 am ]
I don't have longer springs, just raised springs.
Author:  Red89 [ Sat May 08, 2010 11:23 am ]
I guess the search engines broken again.
http://www.auszookers.com/index.php?nam ... 84&start=0
http://www.auszookers.com/index.php?nam ... ic&t=11365
Author:  zooker [ Sat May 08, 2010 12:09 pm ]
Unless you have longer springs they suck. They will make the ride harsher.
Why do you want more lift?
Author:  Rockhopper [ Sat May 08, 2010 10:50 pm ]
pro: you will get a little lift.
con: they are illegal
con: your car will handle and steer like shit
Author:  ajsr [ Sat May 08, 2010 11:28 pm ]
on a stock vehicle with stock springs
cons
wrong castor angles
loose vague steering
not legal
harsh ride on stock springs
how many more would you like
pro if you would call it that
a small cheap lift
Author:  Hybrid [ Sun May 09, 2010 2:34 am ]
Not to mention you will probably chew trhough spring bushes which makes the steering even more scary.
Author:  BlueSuzy [ Sun May 09, 2010 11:14 pm ]
cons
wrong castor angles
not legal
a small cheap lift
More movement with the right springs. But takes time to setup.
Less front ramp angle clearance
