It is currently Thu Nov 05, 2026 9:29 am
Post Posted: Sun May 09, 2010 3:10 am
I'm fitting a roctoy ring but I can't seem to bolt the transfer arms to it as they hit the ring. What have other people done to overcome this? I was thinking of trimming the ring to suit.
Vehicle: MY2019 Jimny
Post Posted: Sun May 09, 2010 3:16 am
If you don't have a BL, then I believe you will need to trim the top edge a bit.
The roctoy ring is a great starting point for a custom made mount, but it does need to be modified to suit your application.
I ended up buying a mighty kong instead, because I didn't have the means at the time to modify etc.
Post Posted: Sun May 09, 2010 3:21 am
I've got a body lift fitted.
Currently, the transfer is out on the bench with the roctoy fitted. I also have the arms out on the bench but the won't bolt in as they hit the ring. (so nothing is in the car yet) I just want to make sure first before I cut it with the angle grinder.
Post Posted: Sun May 09, 2010 3:38 am
if you are jsut bolting the stock mounting arms back on chuck the ring in the bin, its whole purpose in life is to weld bits to it to make a better mount
Post Posted: Sun May 09, 2010 3:56 am
Dammit! Guess I'll have to go shopping for a mighty kong!
Post Posted: Sun May 09, 2010 4:04 am
Try buying one direct from the US, I had mine delivered to my door for about $360 last time the dollar was high.
Post Posted: Sun May 09, 2010 4:06 am
Cheers Lumpa... I'll shoot of an email to lowrange.
Vehicle: Sierra
Post Posted: Sun May 09, 2010 8:31 am
seeing as you already got the roctoy, why not re-inforce your arms and weld the roctoy to it. while your at it you could also incorporate a skid plate too. It's a bit of fab work though.
Users browsing this forum: No registered users and 59 guests
