| bent radiator fins http://auszookers.com/forum/viewtopic.php?f=5&t=11832 |
| Author: | experament-u2 [ Fri May 14, 2010 12:00 am ] |
| Post subject: | bent radiator fins |
hi all well i noticed the other day my cooling system is playing up and over heating when out 4x4ing, so im going to pull the radiator out tomorow and give it a flush and check my thermostat. my radiator also has a pile of bent fins towards the bottem (cause by my old bull bar not covering the base properly) so im planning to straighten them out while i have it out. can anyone recommend a good way to do it? its for a SWB grand vit to |
| Author: | SuziBlu [ Fri May 14, 2010 12:07 am ] |
| Post subject: | Re: bent radiator fins |
Fin comb, only way I know of, and usually only sourced from a radiator or a refrigeration shop |
| Author: | atari4x4 [ Fri May 14, 2010 12:23 am ] |
a fine flat bladed screw driver & a piston ring pick + a steady hand & A LOT of patients. |
| Author: | SuziBlu [ Fri May 14, 2010 12:26 am ] |
lol Gus, an who has a steady hand at our age, life in the bad lane does not lend itself to that. |
| Author: | foonji [ Fri May 14, 2010 2:11 am ] |
atari4x4 wrote: a fine flat bladed screw driver & a piston ring pick + a steady hand & [b]A LOT of patients.[b]
I was ready to stab mine and I hadn't even done 1/4 of it yet. |
| Author: | BlueSuzy [ Fri May 14, 2010 3:14 am ] |
I read patients the other way |
| Author: | atari4x4 [ Fri May 14, 2010 3:21 am ] |
if you stab your hand, you'll end up being a patient... maybe i should have type patience? now i'm confused? |
| Author: | BlueSuzy [ Fri May 14, 2010 3:31 am ] |
Yes! Thats how you spell it. I couldn't remember either. Your lucky i have patience. |
