It is currently Fri Oct 16, 2026 2:23 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
Post Posted: Sun May 16, 2010 12:21 pm
hi just after some help i want to get a bit more flex out of my sierra i have a spoa but think the shackles are stock, if i buy different ones would that give me more flex, if so anyone reccomend some cheers
Post Posted: Sun May 16, 2010 12:27 pm
http://www.suzistore.com.au/shopexd.asp?id=1526
Simple and CHEAP.
I didn't say effective either... I own a coily
:roll:
helloo
Post Posted: Sun May 16, 2010 12:48 pm
DON'T put longer shackles on a spoa vehicle (or any really). and no, will not give flex, mearly take some away.
Post Posted: Sun May 16, 2010 1:05 pm
so what can i do to get more flex
Vehicle: I drive your mum
Post Posted: Sun May 16, 2010 10:34 pm
Figure out what is holding your flex back. Have you checked that your shocks are the correct length. Post up some pics, showing your setup. Have you looked at longer springs/RUF?
In the end how much flex do you need. As long as you have decent flex, a set of lockers and crawler gears will make a much more capable rig than stupid amounts of flex that usually end up with you car falling over.
Layto....
Post Posted: Mon May 17, 2010 2:41 pm
would like to do a ruf but seems like alot of work and i dont think i have the skills to do it, what about removing a leaf spring?
Vehicle: 95 wt,31.
Post Posted: Fri May 21, 2010 7:44 am
taking out leaves will help as long as your shock is up to it. i only run 3 front and rear with stock shackles and it flexs enough. ruf is quite simple.
Post Posted: Fri May 21, 2010 8:36 am
I will have a RUF relocation bracket kit ready in 2 weeks. It makes it pretty much a bolt in mod.
Post Posted: Fri May 21, 2010 8:42 am
Hey Pete,
What will the kit be worth
Heath
1994 zook #12007-2009
1994 zook #2 2019 lets build another
Post Posted: Fri May 21, 2010 8:44 am
Hey Pete,
Heath
Still gathering the costs ( not finished yet) but it should be less than a set of shackles :wink:
Post Posted: Fri May 21, 2010 8:54 am
I take this would be for the back mount of the front spring bracket. How will the front shackle work as far as, will front mount need to be moved the get reasonable steering geometry back,
David
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Fri May 21, 2010 8:55 am
will you still need extended shackles with that bracket?
Post Posted: Fri May 21, 2010 9:03 am
unless he has done something amazing you will, it will simply replace the redrilling the perch
Post Posted: Fri May 21, 2010 9:18 am
You don't NEED extended shackles for RUF. It is easier to use them, but I am trying to engineer a solution that will not reuire the use of extended shackles. You will ofcoarse be able to run extended shackles with this kit, but it will not be REQUIRED.
zuki: the brackets will maintain the factory diff location and castor.
Post Posted: Fri May 21, 2010 9:25 am
that's true you dont but im not looking at extending my chasis and only doing half ruff, but at the same time i need to buy new shackles as mine are 6inch long eye to eye which is way to long for any thing! also fat zook what will be required to install this kit? as in what will need to be done cutting welding?
Post Posted: Fri May 21, 2010 9:26 am
Ok sweet, so what rear springs will need to be used STD rears or can Lifted rears be used (eg 2" lifted rear springs
David
Zuki
Now just drive i
Post Posted: Fri May 21, 2010 9:31 am
Just drilling a few holes hopefully. I am yet to test fit it the kit so you will have to wait for the write up.
Post Posted: Fri May 21, 2010 9:33 am
David
Its set up for STD rears, as 2" lifted rears up front can give the front a higher stance than std's when using 2"lifted in the rear. (hope that makes sense :? )
Post Posted: Fri May 21, 2010 9:36 am
i have a lwb you can use as a dummy car :P and your last thing didnt make sense to me did you mean if you use 2" lifted in the front and 2" lifted in the rear the cars front end will sit higher then the rear?
Post Posted: Fri May 21, 2010 9:38 am
Bingo 8)
Post Posted: Fri May 21, 2010 9:41 am
ahhhh what if you used 2" fronts on stock shackles with your kit and then put extended rear shackles on with 2" rears as well hrmm and my offer still stands for you to test this kit on lwb :P ill wheel it and get lots of pics haha
Post Posted: Fri May 21, 2010 9:44 am
LOL. We'll see. :D
Post Posted: Fri May 21, 2010 10:06 am
David
Pete,
I have tried STD up front and they were way to soft and the car just sunk real low so had to use 2" lifted to bring front up[ to level with the back, thats why I asked.
heath
Post Posted: Fri May 21, 2010 11:38 am
David
Pete,
heath
You used old rears? Or new ones?
Post Posted: Fri May 21, 2010 11:43 am
nah old ones
Zuki
Now just drive i
Post Posted: Fri May 21, 2010 11:46 am
zuki wrote:
nah old ones
There is your problem 8) Old springs suck. I prefer new ones with a leaf or 2 removed.
Post Posted: Fri May 21, 2010 11:55 am
zuki wrote:
nah old ones
Pete,
Here is a pic of my RUF using 2" lifted spring I actually got from you, a while ago. As you can sort of see there is not much if any difference in height between front and rear.
David
Zuki
Now just drive i
Post Posted: Fri May 21, 2010 11:57 am
Looking good Dave. Go the hardtop :youdaman:
Post Posted: Fri May 21, 2010 12:04 pm
I wasn't being sarcastic I am really interested in your kits I was merely pointing out that I tried Old Std's and they were S@$T so I tried the lifted ones and it leveled it up good as.
David
Zuki
Now just drive i
Post Posted: Fri May 21, 2010 12:10 pm
David
You've got me wrong Dave. I was being serious :D I really like the hard tops :D
As for the springs, unfortunately there are infinate combinations of springs, but I can only pic one to base this kit around. At this point in time the kit has not been tested, so it may work out that it requires 2" lifted rears to get the desired result. We will have to wait and see.
Pete
Users browsing this forum: No registered users and 224 guests
