Vehicle: 1.3 Tin Top
Posted: Tue Nov 20, 2012 6:50 am
So after a week of having a nasty exhaust leak and inhaling so much NoX, carbon and fuel vapours its starting to affect my brain functionality its time to put a new exhaust on the sierra.
Ive bought a set of extractors of fleabay, just waiting for them. they have a 2 1/4 outlet.
Should i go 2 or 2.5 inch from the extractors back?
Im pretty sure the cat is pretty much shagged so its either replace or remove, how essential is it (legislation wise) to have a cat?
After that im just going to put a reso on about half way and run it out the back.
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1409 Location: Newcastle NSW
Vehicle: '96 LWB trayback
Posted: Tue Nov 20, 2012 8:06 am
2" at the very most. I've got a cranky 1.6 and still only run 2 1/4 inch.
If the car comes with a cat from the factory, you must retain it. Flex joint isn't needed, they're typically used in East-West (ie: FWD) engine configuration to stop the pipe cracking from torque loading.
With just a resonator it will probably be irritatingly loud. I run with a cat and single muffler and that also is too loud. High flow cat, 2" pipe, 12" resonator and a decent muffler would be my choice.
Posted: Tue Nov 20, 2012 8:12 am
Thanks for the insight.
My cat must be really rooted in that case. atm all i have is a cat and its not that loud at all. I have a tin top, which is better side routed or straight back?
Users browsing this forum: Google [Bot] and 158 guests
