| gear box help http://auszookers.com/forum/viewtopic.php?f=5&t=12074 |
| Author: | honks [ Sat May 22, 2010 9:20 am ] |
| Post subject: | gear box help |
hi i have a 95 sierra and have pulled the gearbox out to replace the clutch i had heaps of trouble getting the box out between the cross member and engine and for the life of me cant get it back in i have tried every thing and no luck please help |
| Author: | steak_knife [ Sat May 22, 2010 9:22 am ] |
| Post subject: | Re: gear box help |
Unbolt the g/box mount from the box. |
| Author: | honks [ Sat May 22, 2010 9:47 am ] |
tried that even tried jacking th engine up to get more room still won't go |
| Author: | jacca [ Sat May 22, 2010 9:50 am ] |
try pushing the end of the box through the linkage hole then slide in on |
| Author: | royce [ Sat May 22, 2010 9:51 am ] |
spin it so the starter hole is at teh top and slip the rear end right in then lift it up and spin it another 90 to clear the exhaust then back the right way and slot it in its a lot easier if the exhaust isnt there too |
| Author: | zuki [ Sat May 22, 2010 10:49 am ] |
honks wrote: hi i have a 95 sierra and have pulled the gearbox out to replace the clutch i had heaps of trouble getting the box out between the cross member and engine and for the life of me cant get it back in i have tried every thing and no luck please help
Honks, where in Ipswich are you? I could offer some assistance give me a call! Cheers David 0409060004 |
| Author: | squirezook [ Sat May 22, 2010 10:56 am ] |
royce wrote: spin it so the starter hole is at teh top and slip the rear end right in then lift it up and spin it another 90 to clear the exhaust then back the right way and slot it in
its a lot easier if the exhaust isnt there too X2 Royce has spelt it out clear as |
| Author: | honks [ Sun May 23, 2010 3:06 am ] |
tried spinning it all different was then got the shits and un bolted left hand engine mount and slid the motor forward a bit and presto slid straight in why didn t i think of this earlier thanks for all the help, is the another name for the seal on the output side of the gear box mine is stuffed and every one at auto barn and repco kepp telling me its a extension housing seal worth $50 bit hard to belive when i got a new rear main seal for $18 |
| Author: | Scrawny [ Sun May 23, 2010 3:13 am ] |
Yes, also known as extension housing seal. $50 sounds a bit much, I'm sure I only paid $15 or so last one I got |
| Author: | zuki [ Sun May 23, 2010 3:21 am ] |
ScrawnC wrote: Yes, also known as extension housing seal. $50 sounds a bit much, I'm sure I only paid $15 or so last one I got
Hey honks, Ipswich City Bearings has them, Talk to Scott or Ryan that's where we get all our seals and bearings from. I recently did mine and it was not that dear less than $20. Also it is a bit to change as you will need to take the clutch cable bracket off and spring from clutch fork and rotate shaft enough so the housing can come off. David |
| Author: | Scrawny [ Sun May 23, 2010 3:37 am ] |
zuki wrote: ScrawnC wrote: Yes, also known as extension housing seal. $50 sounds a bit much, I'm sure I only paid $15 or so last one I got Hey honks, Ipswich City Bearings has them, Talk to Scott or Ryan that's where we get all our seals and bearings from. I recently did mine and it was not that dear less than $20. Also it is a bit to change as you will need to take the clutch cable bracket off and spring from clutch fork and rotate shaft enough so the housing can come off. David You're thinking of the input shaft, he's talking about the output |
| Author: | zuki [ Sun May 23, 2010 4:09 am ] |
ScrawnC wrote: You're thinking of the input shaft, he's talking about the output Arh yes, my bad I was too!!! sorry In that case, it has a bit of a dust lip on it and I think he had to order it in but still was like $16. it is about 9mmor10mm think. David |
| Author: | honks [ Sun May 23, 2010 8:06 am ] |
cheers i will chase it up tommorrow |
