Went for a run today with some newly fitted 6.5's and for the first time ever, my zook blew smoke (grey oil smoke). Previously she hasn't blown a whisper of smoke so i'd like to diagnose the problem so I can get it sorted asap.
After coming down a steep hill where the car has been engine braking with no throttle, once at the bottom and thottle is applied, lots of grey smoke comes out but after about 20-30sec it clears up and there isn't a hint of smoke thereafter. It only happens after engine braking and no other time. I'm thinking valve guides but would like to see what others think.
If it is the valve guides, what's the best method for replacing them? Is it a head-off job? And if so, is it worth getting the head reconditioned whilst it's off?
Joined: Sun Dec 27, 2009 10:30 pm Posts: 134 Location: Under the overpass, South Rd, SA
Vehicle: SJ70: lift, gears, muddies
Posted: Sun May 23, 2010 12:12 pm
I did the same, pulled the head off, sent it out and got it rebuilt. Didn't help the smoke at all. Took the motor out and had it rebuilt and no more smoke!
Its not cheap but should keep it going for few more years.
Users browsing this forum: Google [Bot] and 327 guests
