| Author |
Message |
zooker
Joined: Sun Aug 06, 2006 11:30 pm Posts: 596 Location: Queanbeyan
 Posted: Wed May 26, 2010 8:12 am |
Simple question.
Does the G13BB out of a suzuki carry van (99 to 03 I think) fit into a sierra the same as one out of a Jimny?
Are there any differences between the engines?
_________________ Member of C.O.R 4x4
Highway-Star
Joined: Thu Apr 30, 2009 11:30 pm Posts: 4109 Location: Ipswich
 Posted: Wed May 26, 2010 8:20 am |
They lean over on a big angle/slant  , because the engine is under the floor. Hence the intake manifold and tappet cover is designed to suit this orientation.
Am sort of looking at one of these or a G16/M16? out of an APV for my LJ81, to overcome the diff clearance issue in it.
Other than that I think they are essentially the same motor...
_________________ Clearance Hole Technology
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Wed May 26, 2010 8:50 am |
Highway-Star wrote: They lean over on a big angle/slant  , because the engine is under the floor. Hence the intake manifold and tappet cover is designed to suit this orientation. Am sort of looking at one of these or a G16/ M16? out of an APV for my LJ81, to overcome the diff clearance issue in it. Other than that I think they are essentially the same motor...
 Never seen a M16 Carry, doesn't mean thay aren't out there tho
Sump & bell housing's all on a lean to.
_________________ I used to be indecisive,
Highway-Star
 Posted: Wed May 26, 2010 8:58 am |
steknig wrote: Highway-Star wrote: They lean over on a big angle/slant  , because the engine is under the floor. Hence the intake manifold and tappet cover is designed to suit this orientation. Am sort of looking at one of these or a G16/ M16? out of an APV for my LJ81, to overcome the diff clearance issue in it. Other than that I think they are essentially the same motor...  Never seen a M16 Carry, doesn't mean thay aren't out there tho Sump & bell housing's all on a lean to.
Yeah I haven't either, though I was talking to a workshop mechanic about the idea of the G16 APV motor in an LJ, and he said he would use the M16 from one....
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Wed May 26, 2010 9:00 am |
I think you are in for a lot of work Highway-Star. THe G13BB from the Carry would almost be as wide as the chassis rail measurement of an LJ. The Sump and sump adapter ( a huge wedge shaped alloy casting) are enormously wide. The exhaust manifold is almost the lowest part of the motor and is a horrible log design. I'm also unsure about the bolt pattern. From memory the bellhousing bolt pattern would put the gearlever under your passengers bum if you used one with a sierra gearbox in it.... and poorly oiled.
Dozoor on outers was discussing using one of these in a sierra to lower the COG, but I spent ages going over one when it was sitting on a pallet and it looked like it wasn't worth all the effort for a G13BB.
BlueSuzy
The head maybe designed slightly different internally for oil lubrication on the extreme angle.
Not many people have done this conversion because you never hear of it!
Have you tried redlinegti.com?
steak_knife
 Posted: Wed May 26, 2010 9:03 am |
The pic's i sent you were from a 09 model, so unless the 10 has em, haven't seen any tec sheet's tho.
Highway-Star
 Posted: Wed May 26, 2010 9:13 am |
Gwagonsteve, I have only lightly looked at it for an option, as I want to avoid a dry sump if possible. Once I get my rolling chassis built, I will look at engine options more thoroughly. For the gearbox you'd have to use the matching van Box I would presume? maybe adapted to a Sierra, Jimny or Vitara shifter, or even a much undesirable linkage system...
Yeah, thats what I was wondering Bluezuzy, which engine would be better to run at a less extreme angle for oil lubrication reasons? the near vertical Jimny/Vitara G engine, or the near horizontal Carry/APV G motor? Assuming they are indead different?
I don't know steknig, the bloke I was talking to could have been confused..... because he sure caught me offguard saying use an M16...
Sorry to Zooker for the semi-hijack
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Wed May 26, 2010 9:26 am |
BlueSuzy wrote: The head maybe designed slightly different internally for oil lubrication on the extreme angle.
Here is a bit of trivia, when you put a one litre from a Sierra in a van you have to use the van distrbutor housing so that the distributor clears the floor. However the van distributor gear and the distributor drive on the cam is cut diagonally oposite to a sierra 1 litre so you have to use the van distributor housing for clearance but have to use the 1 litre distributor or the gears wont mesh.
BlueSuzy
 Posted: Wed May 26, 2010 11:55 pm |
Gwagensteve wrote: From memory the bellhousing bolt pattern would put the gearlever under your passengers bum if you used one with a sierra gearbox in it.... and poorly oiled. Steve.
I now remember seeing the Carry g13bb, It has to go in at an angle. The gearbox bolt pattern is set that way so the engine is 45' angle, and the gearbox is vertical.
